NEED HELP> where's the DLC 16P connector (reading SRS cod - Insight Central: Honda Insight Forum
Old 01-28-2008, 12:59 AM   #1 (permalink)
Default NEED HELP> where's the DLC 16P connector (reading SRS cod
My service manual shows this behind the center console but I can't locate it. I'm trying to read the SRS codes.
I have the console out and I'm going crazy locating it. Is it already connected or is it open?
Does anyone have a picture or description of this connector? Thanks,
Jeff
Raysur is offline   Reply With Quote
Old 01-29-2008, 03:56 PM   #2 (permalink)
Problem found. The service manual didn't label its diagram correctly. Older Insights have a data port hidden behind the center console. My 2002 has the data port under the crash pad on the driver's side. I thought the SRS system had its own data port.--it doesn't.
