Front Brake Pad Replacements - Insight Central: Honda Insight Forum
Old 01-31-2008, 03:07 PM   #1 (permalink)
Default Front Brake Pad Replacements
Does anyone know what brand of front pads are best for replacement?
Thanks,
Keagan
keagan is offline   Reply With Quote
Old 01-31-2008, 03:27 PM   #2 (permalink)
Unless you are a racer,,,,,,,,It can be your own preference/.
WIllie
Old 01-31-2008, 06:32 PM   #3 (permalink)
Bought my Honda OEM pads off eBay... couldn't be happier. You will need to make sure that they are the right part# as there are at least 2 different ones. AS far as which ones are "better", that is always subjective as to what you hope to accomplish... the OEM pads ought to last you @ 100K+ miles If drive right so why try to save a dollar or two and take a chance?
Old 01-31-2008, 09:09 PM   #4 (permalink)
Go with OEM Honda. Buy them from one of the online dealers that sell for a discount.
One suggestion:
http://www.hondaautomotiveparts.com/ $34
I've had aftermarket pads ruin rotors and wear out prematurely.
Iggy: 2000 Insight, 5-Speed, A/C, 112k miles -- Holmgren footrest, Armrest King armrest,
IMA battery, BCM & MCM @ 70k, O2 sensor @ 76k, Trans rebuild and clutch @ 94k
devin1955 is offline   Reply With Quote
Old 02-01-2008, 09:41 AM   #5 (permalink)
I'd say any *quality* semi-metallic or ceramic pad will work fine. Make sure it has the metal clip that holds it to the caliper, as this is intended to reduce drag (and increase mpg!).
Quality probably means it will be at least $30. Not $7 pieces of toast in a box from Autozone.
shifty35 is offline   Reply With Quote
