More unusual IMA behavior?
After driving an Insight for over 6 years, with only the stock IMA system in control, I'd only seen the 100% iSoC (indicated State of Charge) 3 or 4 times, and in each case, the weather wasn't particularly cold. This would be where all of the green bars are illuminated.
Earlier this winter (before I began all-temperature bicycle commuting) there were many mornings with temperatures between 0 and 10 degrees F. On several occasions on those cold mornings, with only the stock IMA system in control, I saw forced charging continue to the "all bars" indication. I could see that the forced charge was in effect by the non-stock instrumentation that I have.
(Because of regen - and sometimes assist limitations at those temperatures, manual control doesn't necessarily enable improvements in fuel efficiency until things get warmed up a bit.)
It's assumed that the Insight battery controller doesn't normally charge or discharge the battery pack to the extremes, so as to increase the life expectancy of the NiMH batteries. I recall seeing some information that the early Insight control systems could allow "overcharge" of the pack. My Insight does fall into that "early" category.
What leads me to believe this "all bars" charging situation is unusual is that I hadn't seen it in previous years, with about 90%+ of the car's total mileage being accumulated at that time.
Perhaps the "all bars" charging condition is normal in cold weather? I trust that observant, fellow cold-weather Insighters will weigh in on this.
It's possible that the reason I hadn't seen this previously was that before the winter of 2006/2007, the car had always started the daily commute from a subterrainean garage that was almost never below 40 deg. F. In the subsequent winters, my Insight has been out in the cold, with the battery pack equilibrating to the overnight temperatures.
Last year was a mild winter in this area, enabling bicycle commuting for all but about 25 days that were bitter cold. I don't recall using the Insight much during that time.
As another reminder; the iSoC doesn't necessarily represent the actual SoC of the battery pack.
In summary; I'm interested in finding out if the "all bars" indicated State of Charge is a typical situation for the Insight in cold winter conditions?
'gonEfishnt
2001 5S, "Sputnik"; Various Modifications; 76.6 LMPG at 75K miles
