Re: Battery failures...any rhyme or reason?
There are many reasons for battery failure: overcharging, sitting idle, dendrite formation, corrosion, vibration, manufacturing defects, bad seals, high temperatures, high rate of charge or discharge, freezing. Not all modes of failure are applicable to all chemistries, or to the same degree. In a complex system such as found in hybrids, failure of peripheral electronics, connectors, sensors and poor programing will also have an influence. There are other possible factors including quality control and production defects that would be the responsibility of the original battery manufacturer. Batteries for hybrids will improve with time. There are currently about 200 million individual cells in the over one million hybrids on the road. We are testing these cells in our hybrids in the same way that the internal combustion engine has been tested in the billion or so cars that have been produced in the last 100 years.
Keeping the temperature down in the Insight will help, as will driving moderately, however neither will guaranty long battery life and neither might be the major cause of failure.
On the positive side, the need for battery servicing will eventually create an industry of pack rebuilding, and future replacement cells will likely be an improved design.
Kip Munro
