need swap: Newer engine into 2001 car ? - Insight Central: Honda Insight Forum
Old 03-24-2008, 03:26 PM   #1 (permalink)
Default need swap: Newer engine into 2001 car ?
I want to swap a fresh engine into my 206K 2001 5 speed Insight.
I would like to use a recent engine, but I'm not sure they changed anything past 2001 that might make this swap
difficult. For example, wiring harness ( I could use old one ) , Injectors ? What else ? Cam sensor? Other electrical ?
I would appreciate any experience or advice you guys might have.
Thanks
-Les
-Les
2001 5 speed 207K miles.
--- Google 'Peak Oil' and learn what may be coming too soon ---
lesdit is offline   Reply With Quote
Old 03-24-2008, 05:55 PM   #2 (permalink)
ibjeff's Avatar
Default Re: need swap: Newer engine into 2001 car ?
Here is the site that handles used Insight parts including complete gasoline engines.....hope this helps
http://www.pamsauto.com/search.aspx?SearchTerm=insight
5-speed
Monte Carlo Blue
170000 miles
63.2 lifetime
southern AZ
ibjeff is offline   Reply With Quote
Old 03-24-2008, 08:00 PM   #3 (permalink)
OK, no need for a different year !
I found a 2001 engine and 5 speed with 32K miles for $1600 shipped to my house.
Now I need to buy a new clutch kit and some hoses and belts from someplace.
-Les
Old 03-24-2008, 08:14 PM   #4 (permalink)
wow, that is quite a job, what was wrong with the original motor?
2000 silver MT 122k
121k crankshaft seal
113k p1447 pack/mcm/bcm
105k engine grounds
43k LAF sensor
Old 03-24-2008, 08:49 PM   #5 (permalink)
206K miles. It ticks a lot and grinds 3 to 2 shifts.
Considering that the Insight wants you to short shift constantly lugging the engine, and it's only 1 liter, I'm pretty
impressed that they go so long.
In the old days, you used to hear "never lug the engine, it's bad for it". Now it's " lug the engine, it's good for your FE "
Honda must have beefed up the parts to allow all that stress, I assume.
My transmission also grinds the 3 to 2 shift, which I hate. So I'll shuck it like a clam, and give it a new lease on life.
I just got the car, knowing that I will have to do some work, so I'm OK with it.
If the FE goes up with a new battery, I may even wait to swap the engine and keep it for later.
I can check the valve train and do a leak down test to see how worn the existing engine is. Maybe it's OK for a bit. The tranny
grind is not fun, however.
-Les
-Les
Old 03-24-2008, 09:20 PM   #6 (permalink)
two questions.
did you check the valve lash, and adjust accordingly? maybe the engine is fine, just needs a valve adjustment? the insight engine does tick, especially b4 warmup.
have you tried rev matching and double clutching yet? works like a charm to keep from grinding for many insighters, unless of course your tranny is too far gone. the 2-3 synchro is the first to go, but since purchasing my car a few months ago, I have double clutched all shifts, and rev matched all downshifts, and I can honestly say that it would appear that this practice brings synchro wear to a relative halt.
Otherwise, let the schucking commence.
frank
2000 silver MT 122k
105k engine grounds
43k LAF sensor
Old 03-28-2008, 04:50 AM   #7 (permalink)
I'll check lash soon, the guy I bought it from said it was recently done.
It's more of an internal sounding tick, maybe more like a slight knock, but maybe it's weak on
a cylinder due to bad lash on a cylinder.
-Les
