V-Boost , what is it ? - Insight Central: Honda Insight Forum
Old 03-25-2008, 06:52 PM   #1 (permalink)
Default V-Boost , what is it ?
I saw a reference to V-Boost , and it looks like it is a way to charge extra batteries for on board
plug in usage.
On 99mpg.com the link just goes to a dead end, showing a prius with open trunk, no real info.
Can someone elaborate on this a bit ?
Also, can one add an extra Honda dc-dc converter to the IMA to get some more 12V power, or is the control
circuitry a bit problematic ?
I'd like to add a supplemental electric motor to drive one of the rear wheels ( not a scooter 5th wheel ) and be able to
get some benefit from situations where the main Honda pack is already full, to spill over some charge to another battery, via
a dc-dc converter.
-Les
-Les
2001 5 speed 207K miles.
--- Google 'Peak Oil' and learn what may be coming too soon ---
lesdit is offline   Reply With Quote
Old 03-28-2008, 06:57 PM   #2 (permalink)
Mike Dabrowski 2000's Avatar
Default Re: V-Boost , what is it ?
Doug assures me that he will be getting back to his V-Boost project soon.. The V-boost is a PHEV power dc/dc converter with an adjustable constant current output. It will operate from 48 to 120VCD on the input, and provide 120 to 180VDC output with about 20-25A max.
The same unit with a slight configuration change will also do a PHEV prius. The photo is of Dougs Prius which is running with one of the prototypes.
