Originally Posted by IamIan
I have noticed several times when I install a fully 100% SoC Insight pack that regen was greatly limited and while not extreme the stock IMA seemed more eager to give assist than it normally is... I suspected this behavior was the BCM method of getting the pack back into the middle SoC when it detected that it was at a higher SoC.
That may be what we want, force it to think it's very high soc and very eager to give assist.
The problem with going for 170v or 160v is getting the dc-dc's the 9-0-9 is a standard part. Unless you can think of another way to generate the voltages, I'm not sure about a PD resistor ladder as we don't know the current drawn. And you would still need a 170/160v supply to power it.
Further Testing
Good 60 miles trip today, freezing fog! mpg creeping up and lmpg also clicked up a notch which it never normally does in the winter
Batteries warmed up to about 15C, and now got 75% assist, which I held on some punishing hills for several minutes. No cutback or signs of fan activity from ipu compartment.
What have I learnt so far.
1) The Insight can take a lithium pack.
2) The Highpower li-fepo4 40ah cells seem able to cope with the full regen and 75A assist in the temps experienced so far
3) The BCM although a bit confused seems able to cope without throwing errors, under prolonged heavy load the soc will go below 3 bars, but with gentler discharge it appears to stay at three bars for a very long time.
Advantages over nimh packs?
1) More capacity and minimal self discharge balancing issues.
Could be left for several months without issues.
2) More effcient charge discharge energy usage, less wasted energy. You get out almost what you put in
Disadvantages
1) Expensive
and requires BMS although that can be quite simple.
2) Requires MIMA to operate effectively.
3) Quite heavy and compromises load carrying/cargo space. (If I was doing this again I would try and squeeze it all into IPU compartment.)
Conclusion to date.
Perfomance is amazing and car can cruise with one bar of assist at 145mpg on the flat for miles, I can't wait for the weather to improve
I only need to put a couple of gallons in at a time now as mpg is so high, also means I can ofset the weight of batteries by not filling it up.
