Just Back from my trip 110mpg (UK) for the 270 miles. Not as good as I hoped (Reasons below) but not bad considering and a lot learnt.
1) Weather apalling snow/rain and wind. Temp 5C max
2) Hilly terain with lots of ups and downs.
3) BCM 3 bar bug/feature disabling assist at critical times.
The good news was no ima errors or codes and assist worked fine and I just about managed to flatten batteries after about 130 miles. Assist power went from 50% to 100% as cells warmed during journey, temps started at about 5c and finished at 22C and went to 25C after being charged.
The problem was the BCM bug which with a much larger pack was much more obvious. Yes after the initial pos recal you could drain down to 3 bars and a total of about 8-10ah out, but then it would drop off and you had to regen to get back to 4 bars or you lost assist. Sadly this kept happening at bad points on the journey and when faced with a 5 mile gradient to climb
I was a bit unlucky but you were then forced to climb with no assist or even while charging destroying you previous figures
I almost stopped at the side of the road and thought allowing it to regen there to 4 bars might have been better than continuing with no assist.
So basically it works but I need to fool the BCM with the current in and out hack. I'll implement that this week and report back on MIke's resistor tweak.
The 3 bar drop did not seem to be voltage related, but my cells never went near the bottom cut off voltage.
The cell remained well in balance and worked fine I was very pleased with them.
My BMS Soc counting worked well, still over reading amps a bit, but very interesting to watch.
Had a long and interesting chat with Greg Fordyce a UK EV enthusiast and one of my BMS supporters. Went out in his two EV's one running Lithium and our BMS and one running pb gel. Both very good.
