Just thinking outloud/pondering the choices for measuring current in and out of the pack.
I want to get current in/out into my PIC battery monitor 24/7 even when car and MIMA are off but car is grid charging from mains.
The BCM will still be connected anyway and it will do it's own thing with the 10X capacity pack during normal driving etc, it may think things have gone awry when it doesn't run out of steam after 4ah, may have to use IMA current sensor divide by 10 trick.
So I see the following options.
1) Leave the car/mima turned on and piggyback onto MIke's conditioned 0-4V -100 to +100A MIMA output and send that to my PIC.
2) Power MIMA and the BCM/Current monitor somehow whilst rest of car is off and then as (1) above. I don't like this idea.
3) Use my own independent current transformer on the main + powered by my own pic cicruit, I quite like this idea.
4) Use one of these devices with a torroidal core (may not be needed) and it provides a linear output with 1/2vcc as the null point. Looks too easy!
http://picasaweb.google.com/picaxe/Inpu ... 0012399298
http://www.datasheetcatalog.org/datashe ... s/3503.pdf
Thoughts.
