Just a litle update, tweaked my display install and seperated video signal from within the multi core lead I used initially, it was functional but a bit noisy, now it looks crystal clear with separate ground and signal wires and a nice HQ coax cable and gold plated connectors
Might as well get it right.
Two pics showing driving position and display/control, and another youtube video when it's finished uploading explaining it a bit more
www.solarvan.co.uk/insight/DisplayInstall1.jpg
www.solarvan.co.uk/insight/DisplayInstall2.jpg
Hopefully better audio quality this time on video as I changed encoder setting from Cheapskate 64kb to Imprudent 128kb
http://www.youtube.com/watch?v=SBYJXj4pUrk
Master current consumption testing on the BMS also quite comforting.
With screen on it's about 185ma from 12v supply
With screen off it's about 90ma from 12v supply
Once it's driving the charging relay that will rise a bit, but not bad and capable of running from the Car pb battery without much risk of flattening it unless left on for a week or so.
