just casually discovered an additional problem ... the Insight's AC compressor according to the service manual ( 2-13 )... is a Sanden Scroll that pumps out up to 12,700 BTU per Hour of cooling... In addition to the drive system load it also pulls up to 300Watts of electrical power.
So any type of alternative would have to put out around ~12,000 BTU in order just to equal the OEM system.
of course generally it is more efficient to drive a compressor directly... to use electrical power you add in additional losses... there are a few benefits... one is that it would work while in Auto-Stop.. so the engine wouldn't need to idle to keep cool... one is that it would allow you to do a load balancing system for the cooling needs over a larger period instead of having the AC pull the power from your drive system at inconvenient times... another is that the electric powered Air conditioners are more driven to be efficient , thus it might be possible to trade the less efficient electrical usage for a more efficient system, the combination might balance out.
the Insight AC system seems to add ~31 Pounds to the vehicle which is very light... probably a primary concern.
The Saden Scroll power graphs look like the power consumed is ~6 kW ( ~7HP ) for those 12,700 BTU... or about 2 BTU per W... which is not so good... this seems ~ about right... I would have guessed closer to ~5 HP of loss but... maybe Honda has a more efficient model than the normal Saden Scrolls.... maybe as much as double at most ~4 BTU per W... which would still be ~3kW or ~4 HP.
If you are willing to drop to ~1/2 the cooling capacity down to ~5,000 BTU per Hour...
dcbreeze
Runs on 12VDC or 24VDC and uses ~580W which is better than the standard Saden Scroll at ~8.6 BTU per W
Now in addition to the 1/2 cooling power, you also gain the ~50 Pounds of this unit... so it weighs ~18 pounds more than the Honda OEM system.
The most efficient electric AC unit I know of is
SolCool
Unfortunately this model is built for stationary use and is far too big and heavy for vehicle use...
But it does dish out ~15,700 BTU and only consumes ~1,000 Watts to do it.
This gives 15.7 BTU per W of energy...
So while no one seems to make one for vehicle applications ... this level would at least be technically possible.
Unfortunately you can't directly compare the Watts ... because the Watts of the Insight compressor come directly from the ICE... where will you get the electrical watts from... if you say the ICE via alternator function... ~10% loss ICE to Electrical High Voltage ~10% loss High Voltage to Low Voltage DC-DC... means you loose an additional ~80%... if you use the batteries to store extra energy .. which seems like a given... you can knock that down again by ~80%... so you end up with about ~65% maybe ~70% of the energy you take from the ICE combing back to the electric AC unit... this means it has to do at least ~35% better just to break even.
Thankfully the DCBreeze looks like it is more than ~35% better ... but you take a 18 pound hit... you have to find some place to put the thing... it won't use the stock Climate control system.... and a fully charged OEM battery Insight will only power the thing during Auto-Stop for ~45 Minutes at most.
Now once you start pulling that much power you will pretty much force the IMA into forced charging... which takes away the power you saved .... unless you have some other larger source of electrical power not related to the ICE...
But would this be a good use of electrical power?? ... I have my doubts... After all if you have the electrical power to run this thing ... then you might just be further ahead to use that electrical power to drive the IMA system to move the car.
but there you go.
