Battery Voltage Sag under IMA load - Insight Central: Honda Insight Forum
Old 05-26-2008, 12:01 AM   #1 (permalink)
Default Battery Voltage Sag under IMA load
Anyone have any numbers on how far battery voltage sags during full assist?
I understand fully discharged voltage is about 140-145v is that correct?
Doe's it sag below this under load?
Save me putting a voltmeter across it during use
Old 05-26-2008, 01:03 AM   #2 (permalink)
uhtrinity's Avatar
Default Re: Battery Voltage Sag under IMA load
I see anywhere between 140v - 145 v before the BCM cuts power, this of course is unloaded. Under load the values can easlly be 5 - 15 volts lower.
Mark
2000 Silver Insight, #5550
uhtrinity is online now   Reply With Quote
Old 05-26-2008, 01:06 PM   #3 (permalink)
The BCM limits assist current once the battery voltage drops below 120V.
Armin
2000 Insight 3085
MYBRID
Armin is offline   Reply With Quote
