I'm confused here. So the procedure is:
1. Use the "increased EGR" configuration. What was your "best" ohm setting out of the 10kohm pot?
2. There is no capacitor used in the setup correct?
3. From the diagram shown
http://us1.webpublications.com.au/stati ... 55_6lo.jpg the wht/blk wire is cut a few inches away from plastic connector that plugs into EGR Valve. Wh/blk end from plastic connector soldered to one end of pot. The other wht/blk end is soldered to the variable output of the pot.
4. Grn/blk wire is stripped of insulation 1/4" and the other fixed end of pot connected.
End of EGR mod?
PS, where can we find your "increased ignition timing" mod?
