Compression Ratio and lean burn - Insight Central: Honda Insight Forum
Old 06-25-2008, 09:11 AM   #1 (permalink)
Default Compression Ratio and lean burn
Does anyone know where the half point difference in compression between CVT and 5 speed comes from? i.e. head gasket, piston deck height, or other? Also how is the lean burn on 5 speeds accomplished and can it be applied to a CVT? Maybe a computer reprogram or swap?
1990 SS454 pick up 8mpg (54k original miles)-1975 Monte Carlo (18k original miles) 496ci 800hp, 3gal/mi, 2003 Insight CVT Red 100,966k (Greta)
TopFuel500 is offline   Reply With Quote
Old 06-25-2008, 09:28 AM   #2 (permalink)
joecvt's Avatar
Default Re: Compression Ratio and lean burn
Awhile back, I did a parts comparison at majestic honda and the only difference in part numbers for the major components that you mentioned are the pistons so I believe that is where the compression ratio difference occurs.
When rebuilding the engine, you can order an oversize piston. That part number is the same for both models so you may be able to modify the CVT compression ratio during an engine rebuild (assuming the oversize piston is designed for the compression ratio of the MT model).
There are actually many components that are different for lean burn. Besides the main ECM (computer), there is a different catalytic converter. Here is a portion of the description from http://www.insightcentral.net/encycl...catalytic.html
During lean burn operation, the exhaust gas contains a larger percentage of oxygen (O2) and NOx, the NOx being primarily nitrogen monoxide (NO). The platinum catalyzes the O2 and NO to produce nitrogen dioxide (NO2), which is able to be stored on the Ti-Na surface.
When it determines that the Ti-Na surface is saturated, the Insight temporarily richens the mixture. This action decreases the NOx and O2 in the exhaust, and raises the levels of hydrocarbons (HC) and carbon monoxide (CO). The platinum is then able to use the HC and CO to catalyze the NO2 (that has been stored) into harmless nitrogen gas (N2), carbon dioxide (CO2) and water vapor (H20).
Even the fuel lines are different between the two models....So I believe it would be very difficult to convert a CVT to lean burn...I remember reading in this forum a long time ago that there was a Japanese CVT model that was lean burn equipped.
No other mods performed yet
2003 CVT Blue Insight
Low Speed Auto Stop (LSAS)
Not registered yet
