Originally Posted by dfiore
I know all about MIMA and Mike's genious invention. KUDOS Mike! I have not heard of PHEV. What is that?
P.H.E.V. stand for Plug-In Hybrid Electric Vehicle.... doing a web search will result in many finds... mostly Prius related.... Other Popular PHEVs include the Chevy Volt... and the Aptera.
The basic idea is that additional electricity is used as a energy source to reduce the amount of gasoline needed to move the vehicle.
A PHEV combines the ease of use of a gasoline car as it can be used as a normal HEV.
It also gets some additional benefits of EVs as Electricity even from the U.S. Grid is cheaper and cleaner per mile to move a vehicle than gasoline is.
Ideally you can get the PHEV's electricity from a much greener source than the U.S. Grid such as solar or wind power... this makes the vehicle even greener than a grid charged PHEV.
Many PHEV's that have a pure EV ( Electric Vehicle ) mode of operation have short distances such as ~30 miles or so that they can run as just a EV.. then for longer trips or when you don't want to spend the 4+ hours to charge the batteries you drive it like a normal HEV ( Hybrid Electric Vehicle ).
A Basic PHEV Insight conversion does not give a very good EV mode , but still allows the Insight even as gas light and sipping as it is to sip even lighter and offset some of the gasoline it would have used with stored electrical power instead.
Mike D's V-Boost for his Insight is an example of a PHEV Insight conversion... during the time his batteries provide boosting charge he has often reported easily being able to get 100+ MPG where he would have gotten ~60MPG without it.... Mike also uses his solar panels to charge his Insight PHEV batteries so he gets even more green vehicle points.
Other Insight Central Forum Members have also been adding various variations of PHEV modifications to their Insights... some just by grid charging the 4Ah in the stock battery... others have added used Civic HEV Battery packs to bring their on vehicle energy up to 10Ah ...
