new suspension
Hi folks:
I've lurked here off and on to learn more about my Insight, a 2002 with CVT, which I purchased used. I've thought the ride was too soft and the rear suspension travel too limited as it was too easy to bottom. After searching this forum regarding shocks and springs, I finally decided to get a custom set of springs from Coil Spring Specialties as some previous members have done, as well as some new OEM struts and shocks.
I ordered the front springs at stock height and 25% stiffer, and the rear springs with an extra 1/2 inch in height and 35% stiffer. Coil Spring Specialties already had the dimensions for the springs, so it was pretty straightforward for them. I ordered the shocks and struts from Majestic Honda.
I just got back from the shop and initial impressions are very good. The car has a firmer ride and it feels like there's an actual suspension on the car now. Previously, the car like it was sagging on the suspension and now it feels like its on its toes, a more sprightly and sporty feeling. There seems to be more give in the suspension now, even though the springs are stiffer.
Since I changed both the springs and the struts/shocks, I can't tell what has made the most difference. The new springs are noticably larger in wire diameter and seem bigger. I wish I had taken measurements now. It could have been my shocks were worn out. My car has 50,500 miles or so, and I'd expect OEM shocks to be pretty dead by then.
At the moment, I'm quite happy with the package. I like the firm ride, there's a lot less pitching now on acceleration and braking, more body control, and I expect the handling has improved. I wish I could get anti-sway bars for the car as well to get rid of the roll. Braided stainless brake lines would be nice too.
I'll followup after I put more miles on the setup.
