Engine change advice - Insight Central: Honda Insight Forum
Old 08-27-2008, 04:30 PM   #1 (permalink)
Default Engine change advice
Hi,
I am ready to do an engine change for my 2000 MT. I have a 2003 CVT that the tranny is bad but the motor is good so I decided to swap the motor out of the 03 into the 2000. Any advice will be appreciated.
Joe
Joekingiam is offline   Reply With Quote
Old 08-28-2008, 12:53 AM   #2 (permalink)
uhtrinity's Avatar
Default Re: Engine change advice
You will take a mpg hit, even if it it hooks up electrically. Read the recent lean burn cvt engine thread.
Mark
2000 Silver Insight, #5550
Old 08-28-2008, 08:45 AM   #3 (permalink)
Thanks for your reply,
So am I understanding you correctly, the 03 cvt tranny and engine is different then the 2000 M.T. tranny and engine other than the obvious transmission difference?
Are you saying then the way to change my motor is to swap Mt/Engine for MT/Engine?
Joe
Old 08-28-2008, 01:47 PM   #4 (permalink)
Yes!
IICR the CVT has lower compression also.
