Also:
Flooding the spark plug well with a suitable penetraiting oil _prior_ to you attempted removal, allowing sufficient time for the oil to penetrate, _and_ gently using _hand force only_ to remove the plug can prevent further damage. 1cm+- deep is sufficient. Carbon is now caked in the threads. Forcing the plug out can also damage threads.
When removing, should the plug become tighter, gently retighten to help draw the oil deeper into the threads and soften the carbon. Then proceed with removal. This process could take several repetitions before the plug is sucessfully removed. And it value for possible prevention of thread damage should not be underestimated (take your time). However, its usefullness has its limits and after more than 10 repetitions, if increasing progress is not being made, the damage may be too great to overcome.
Should an excessive amount of oil be used (sometimes beneficial) then the engine should be cranked with all spark disabled and the plug in question removed to blow out the excess oil. Hydrostatic lock will severely damage the connecting rod. Remember to cover the hole with a rag before cranking
HTH!
