How to Build a Hot Air Intake - Page 3 - Insight Central: Honda Insight Forum
Old 04-17-2009, 09:23 PM   #21 (permalink)
joecvt's Avatar
Originally Posted by 3-Wheeler View Post
Hill Climb with Resonator
RPM's TPS
1250 18.5
1558 19.5
1775 19.5
Hill Climb w/o Resonator
RPM's TPS
1300 24.0*
1565 18.7
1855 19.0
* The car did seem to let me know that it was indeed working harder at this throttle setting without the resonator. The engine had a slightly 'harder' vibration to it at this point, and more noticeable than with the resonator installed.
Hi Jim,
Thar is quite a difference at low RPM. Seems like your initial gut feeling the first time driving without the resonator was correct
I think that I did not see this simply because the CVT will adjust the ratio to a higher RPM if the throttle had to be pushed to 24% opening.
I replaced the pictures of the updated reposistioning of the automatic warm air intake mod. I left the names the same so the oringinal posting will still work but will have the updated pics.
To make it easy for viewing, here are just the pics of the update.
http://74.92.0.194/misc/insight/air-...r-intake01.jpg
http://74.92.0.194/misc/insight/air-...r-intake02.jpg
http://74.92.0.194/misc/insight/air-...r-intake03.jpg
http://74.92.0.194/misc/insight/air-...r-intake04.jpg
http://74.92.0.194/misc/insight/air-...r-intake05.jpg
http://74.92.0.194/misc/insight/air-...r-intake06.jpg
http://74.92.0.194/misc/insight/air-...r-intake07.jpg
The tube that goes from the cat to the air mixer is now all one piece that goes under the battery. It is wrapped with tons of duct tape for stength and some insulating value. After the initial duct tape wrapping of several layers, there are two layers of insulation tape (R2 value for each layer), then another wrapping of duct tape as a final layer. So I know that it is at least R5 value or more with all of the wrappings.
I was able to shorten the length of the insulated tube by repositioning the angle of the warm air inlet 180 degress from the stock part so now the inlet faces the rear of the car.
Also, the metal air mixer is double layered insulated as well.
We will see how next winter goes
2003 CVT Blue Insight
Low Speed Auto Stop (LSAS)
2004 CVT Red Insight
2001 MT Blue Insight
Installed clutch switch with relay for AutoStop
(on the road with 290,000 miles)
Old 04-18-2009, 09:37 PM   #22 (permalink)
3-Wheeler's Avatar
Hi Joe,
Thanks for the pictures of the new layout. Looks like I can continue to invest in our favorite DuctTape stocks .
One thing I can not tell from the photos though is where the resonator attaches into your overall system? Also, where does the hot/cold bypass attach?
If we decide to use Honda's original design and keep the inlet diameters/lengths the same, then the bypass valve should be located at the effective end of the snorkel, where ever that may be located.
The spacing of the resonator 'tee' relative to the end of the snorkel provides part of the 'tuning' in the overall design of a resonate system that Honda has put together. The tube diameters and lengths, along with the resonator hose length to the resonator cavity itself, all act together to keep a tuned resonance in the 1300 rpm range. The resonance is probably tuned even lower than that based on a hunch, but I had no idea how low the tuning went before the testing, and did not consider this RPM, but have a strong suspicion it goes this low.
The end of the stock snorkel provides the function of an acoustic reflector, so placing your bypass valve there will still cause a disruption in the smooth surfaces of the piping and get the desired tuning back to Honda specs, if it isn't already. There definitely needs to be an abrupt expansion of tube diameter at the stock location of the snorkel away from the inlet filter box to maintain the inlet tuning. You can take a look at my former post for more theory on this. The trumpet flare would be an excellent choice here as well, which would then feed to the catalytic converter.
So to recoup a preferred design:
_ Using the stock Honda lengths/diameters, work backwards from the airbox to the resonator 'tee' connection. Measure the average length of this piece of tubing to the tee. Which ever way you decide to plumb the tubing, insure that this length to the tee is the same.
_ Make/fabricate a 'tee' of the same dimensions and place in the system at this point.
_ Measure the length to the end of the snorkel from the 'tee'. Create a stretch of tubing any direction you wish using this same length.
_ Place your bypass valve at the snorkel length measured above. If you attach the bypass with tubing to the snorkel location, then keep that tubing short, like under 1 inch if possible. A longer hose will again change the tuning of the acoustic circuit.
_ Also in the same spot, create a trumpet flared section that is let's say at least 3 inches in diameter at the largest part of the flare. The trumpet flare overall dimensions are 1.5 inches at the small end, 3 inches at the large end, and make the flare length about 5 inches long. Look at coronets, trumpets or trombones for inspiration on creating this shape. Ideally, you would want to 'tee' your bypass valve in the large portion of the flare (on the curved side-wall somewhere).
_ Orient the flare such that the large end faces the bypass valve and air box, and the small end faces the catalytic converter, where the hot air pickup is located.
_ To finish the air intract, connect whatever tubing you need from the small end of the flare to the catalytic converter. The length of this tubing is not critical as long as the flare in is place. If the flared section is deemed not important, then the effective end of the snorkel will end up being at the catalytic converter, and effectively change the resonant frequency of the tuned system.
I hope this information is not coming too late, as you have obviously put much effort into your system, so if I am late, I apologize.
Actually my own hot air intake has been functional for several weeks now, but when I redo it, I plan on 'modeling' the system by shaping hard foam insulation by gluing/cutting/shaping until I get the layout correct, then fiber-glassing over the outside of the foam, cutting the pipe into sizable sections, gutting the foam, then reattaching the overall piping with rubber hose and clamps (DuctTape?? ). The fiberglass will be thicker at the hose connection points for stability. Worm-gear hose clamps have a tendency to D-shape tubing and distort it.
I will also, as you have, place a suitable insulating material on the outside of the fiber-glass to get the R-value up. It might be fiber glass batting or GreatStuff expanding foam. If anyone decides to try the expanding foam, just practice on something else first, as this stuff can get really messy for those who are not familiar with it.
I will take your idea of the air bypass, which does seem to be essential for the various temperatures through out the year, and probably simply run a choke cable into the cabin where I can 'roughly' estimate a setting for the various seasons. Not quite as elaborate as yours though .
Hope this is not too winded, but the acoustics in this system are not admittedly simple.
Hope all of this lengthy discussion helps, Jim.
Old 04-18-2009, 10:32 PM   #23 (permalink)
joecvt's Avatar
Hi Jim,
In my new design, I shortened the length of the air mixer valve so that I could possibly squeze a T fitting to attach the resonator tube if it seemed to make much of a difference. I also wanted to have some air enter under some pressure when traveling at highway speeds so I have not put in the T fitting for now.
The hot / cold bypass is really upside down from what you would typically see. If you look at piicture air-intake01 and then take a look at:
Honda Automotive Parts
Imagine cutting off the metal portion of the air cleaner assembly that has the mixer valve, then flip it upside down, cut off the warm air inlet tube and re-attach 180 degrees oposite, attatch a rubber 2 inch fitting to the metal opening, insulate and wrap with duct tape and that is what you see along side of the Insight air cleaner box.
Number 14 in the link I provided is the control vacuum valve that opens and closes the internal gate / flap. Mine is underneath since the whole unit is upside down.
This air mixer metal piece does take up some room so I don't think it is possible to mount it where the stock inlet lays (if I was to put it back on).
It seems like the only area where there is enough room for the mixer is along side of the air cleaner box.
You may be able to find a smaller unit but I already had this one from my original 1984 Honda CRX just sitting around.
Old 12-01-2012, 09:42 AM   #24 (permalink)
Need4Speed's Avatar
I am doing a hot air intake. How hot does the cat shield actually get? Can I connect to it with PVC pipe? Can I use high temp rtv used for exhaust gaskets, good to 600 degrees?
2001 Red CVT
Email dave@groe.us
Old 12-01-2012, 01:56 PM   #25 (permalink)
3-Wheeler's Avatar
I have not had my Hot Air Mod hooked up for a while, but I doubt PVC pipe would *safely* take the temperature next to the CAT.
I used the paper/metallic piping for carburetor heaters and it held up for about two years before breaking from vibration next to the CAT shield pipe.
Jim.
