SRS problems? - Insight Central: Honda Insight Forum
Old 09-23-2008, 07:59 PM   #1 (permalink)
JimIsbell's Avatar
Default SRS problems?
The SRS light is always on in my car. I haven't done anything about it till now because there were other things pressing. But now things have calmed down so I am, going after that one.
I was told it could be just a corroded contact.
Should my first look be at the connectors behind the glove box and the one in the steering column?? Or is there anothe more suspect place??
Old 10-11-2008, 05:01 PM   #2 (permalink)
JimIsbell's Avatar
Default Re: SRS problems?
OK, back again. I finally drained the swamp and the alligators (battery problems) are gone. Anyone have any suggestions on where to start looking for a bad connection that is causing the SRS light to come on???
