Installing Cruise control
Hello,
I am in process of installing Rosta Cruise control in 2002 CVT Insight and have a few questions.
Does the tach signal have to be connected and is so where do I connect it ?
There are two wires that appear to be for brake, can they be connected to one of the two switches on brake pedal or is it necessary to use the switch that cam with cruise control ? It does not look like there is a good location to install a third switch on brake pedal.
The instructions say one wire is for constant 12 volt on brake and other to switched 12 on brake, is there a reason to connect constant 12 volts at brake switch or can it be tied to 12 volt that comes on when powered up (accessory 12 volt) ? Is there a more convenient location to get the brake signal from than at the brake switch next to brake pedal ?
I have read the installation account that Tim Hudson wrote but it is for a manual transmission and does not cover the CVT so what differences are there in the installation ?
I have been putting off the installation for several years now and am hoping I can get it working.
Thanks for any help,
George K
