Re: Clutch Fluid Change Interval?
No, The clutch fluid does not pick up "heat" as the brake fluid does.
If you never add fluid to the clutch master cylinder, it can be used as a gauge to how the clutch is wearing. When the level gets to the "minimun" level, the clutch may be getting close to be needed replaceing.
The choice is yours.
I change the coolant and brake fluid every 100,000 miles. The clutch fluid is always monitored
