Is the TPS also known as MAP sensor? - Insight Central: Honda Insight Forum
Old 12-17-2008, 08:23 PM   #1 (permalink)
Default Is the TPS also known as MAP sensor?
I'm attempting to install the TPS mod, but so far, I haven't been able to find the location of the TPS. Is it labeled as MAP on the sensor itself? Illustration #11 in this drawing? http://www.hondaautomotiveparts.com/aut ... OTTLE+BODY
Also, in the tps mod, would the positive leg of the cap connect to the red wire going to the sensor(after you cut the red wire) or the red wire going to location unknown, since it dissappears into a plastic cover.
Best trip 9/3/2007 226mi 4hr 45min Avg 47.5 mph 97.9MPG
Best tank 9/17/2007 fillup 9.89gal 895.4mi traveled Calculates to 90.5 MPG. Meter read 87.6MPG
TPS mod
JakkedUp is offline   Reply With Quote
Old 12-17-2008, 09:21 PM   #2 (permalink)
02insight's Avatar
Default Re: Is the TPS also known as MAP sensor?
I think TPS and MAP are 2 different things
TPS = Throttle Position Sensor
MAP = Manifold Absolute Pressure Sensor
TPS sensed the position of the throttle plate, while the MAP senses the pressure in the manifold
Old 12-17-2008, 09:26 PM   #3 (permalink)
The TPS and MAP are indeed different sensors.
IMO the mods are of limited value with potential detrimental emissions consequences. Such has been exhaustively discussed in the past. Multiple threads on the same topic especially by the same OP are discouraged here at IC (your recent eariler thread, this reads more like a follow-up).
If you don't know the difference maybe you should reconsider DIY. Or IMO even at all.
02 5spd, 130k+Miles
Old 12-17-2008, 09:33 PM   #4 (permalink)
02insight's Avatar
here is a better diagram which shows the TPS. Its on the other side of the throttle lever
