Originally Posted by gpsman1
Originally Posted by lenwardus
When at a Honda dealership buying a Civic Hybrid the salesman said don't ever run it out of gas as
that could cause permanent damage to the batteries and void the warranty. Would the Honda hybrids
keep going on just electric power if the gas tank ran dry?
I think only if you have MIMA installed.
You might be able to get a little, short-lived electric propulsion.
Can anyone with MIMA confirm or deny?
( I should have my MIMA by the end of this month! Yea! )
I think the original post means, you can go 20 miles past when the car SAYS empty, or zero bars on the gauge.
I think (most/all) of us have done this.
I can confirm that you can run the Insight with MIMA in a pure EV operation with no gas... because I did it and posted about it here on IC ~ 2 years ago.
But, as it has been said... not very far... because of the air pumping losses caused by turning the ICE ... and because you only have at most a bit over ~500Wh of available battery power ... maybe less depending on the SoC.
My best when I tested it was ~3.7 kM starting from a stop and it was pretty much ~ flat / level ground.
HERE:
If you were already in motion you could probably get further... if it was down hill further still.
Also ... although I would not recommend doing it on a regular basis... when the car runs out of gas... if the IMA system is engaged at that moment ... providing enough power to keep the engine RPMs above 1,000 ( preferably ~2,000 or so ) you can continue to drive even if you do not have MIMA as long as you can keep the assist level going to push you along.... even without MIMA this can be done just by flooring the gas pedal... you will get assist until the SoC gets too low and then it will cut out.... of course with MIMA it works a bit better because you have proportional control of the IMA... instead of having to floor the gas pedal to make sure you get the assist.... so as far as I can tell anyone MIMA or not... in a Insight should be able to get a short distance if they get the IMA assist going before they run out of gas and just keep the gas pedal down enough to keep on going even if you have no gas left...
Continued operation like this is probably not very healthy on some parts of the car.
