I would like to know the following:
( although this is a long shot at best )
#1>
What are the actual operational limitations ( technical details ) of the IMA motor?
( 10kW is published... but motors always have more technical details about them when a company buys , or builds them... especially to the engineers working on it / with it. )
#2>
What are the actual operational limitations ( technical details ) of the MDM?
( We know it does DC to AC 10kW Assist , and AC to DC 5 kW Regen... again there has to be more detail from building and buying companies / engineers. )
#3>
If emissions were not a concern, would there be a technical reason for the Insight's system not to operate in Lean burn 100% of the time ? If so what is it / details ?
#4>
What are the rolling resistance numbers / details abut the OEM tire?
We know the Cd and Aerodynamic stuff... but when they came up with the MPG number to publish... and when they were looking around at different tires... they had to at some point also get the coefficient of rolling resistance for the OEM tire the choose and likely also how that changes with temperature and such.
#5>
I don't suppose they have any spare copies of the source code / schematics for the BCM?
Like the ones they didn't want to keep around.. you know with coffee rings or something on them
#6>
What are the conversion efficiency numbers for the transmission?
