Easiest cruise control mod for 2000MT? - Insight Central: Honda Insight Forum
Old 01-14-2009, 08:14 AM   #1 (permalink)
Default Easiest cruise control mod for 2000MT?
Hi,
I have to install cruise because my back and legs have nerve problems, My Prius has cruise and I am about ready to start driving it again. I would rather do a mod for my Insight so I am open for some feedback. Thanks
Joe
Joekingiam is offline   Reply With Quote
Old 01-14-2009, 05:47 PM   #2 (permalink)
Default Re: Easiest cruise control mod for 2000MT?
Checked the Owner's Modifications pages yet
(links on the top of each forum page )
http://www.insightcentral.net/owners/mods/index.html
HTH!
02 5spd, 130k+Miles
Old 01-26-2009, 09:15 PM   #3 (permalink)
Smile $267 for my cruise mod
Thanks again Insightful trekker because after doing my homework and shopping the net, I went to my local Summit racing and gave them a printout of what Brandon Distributing would sell the parts at $252, so Summit beat it by 1$ added the tax and thats the rest of the story.
Now comes the fun part - the install.
Joe
Old 01-27-2009, 03:25 PM   #4 (permalink)
JimIsbell's Avatar
Has anyone done a test to see if cruise control or just plain foot are better for mileage? I am wondering about the cruise controls ability to stay in lean burn on the MT.
Old 01-27-2009, 04:12 PM   #5 (permalink)
bryankwalton's Avatar
No official testing, on my part. But I believe it is generally understood that you will get better fuel economy without using cruise control. The reason for this is that cruise control is generally designed to maintain a set speed -- even on hills. When hypermiling, if you allow yourself to decelerate some going uphill and either let off on the pedal or even FAS when going downhill, your fuel economy will be much greater than anything offered by cruise control.
Cheers,
Bryan
2000 Honda Insight -- Lifetime Fuel Economy of 71.6 MPG
Old 01-28-2009, 11:27 AM   #6 (permalink)
JimIsbell's Avatar
Down here in south Texas, everything is flat. The change in elevation on the 200 mile trip from Corpus Christi to Houston is less than 200 feet. But I still think that the cruise control, not being tuned in to find lean burn would likely be less economical than a foot.
Old 01-28-2009, 04:25 PM   #7 (permalink)
I've wondered about the possiblity of adding some terrain "smarts" to the cruise control. GPS could be used to look ahead for changes in elevation, or for shorter look-ahead, a front grill sensor that might bounce ultrasonic or laser off the road ahead and read the bounce back.
For lean burn, perhaps a feed back loop could be added that might run the cruise control ±4 mph from set speed hunting for lean burn then trying to keep it in the zone?
-John
JohnHeller is offline   Reply With Quote
Old 01-29-2009, 07:59 AM   #8 (permalink)
On our CVT, the tach increases slightly on uphills, as you would expect, to maintain a steady speed. But on the downhills, the tach shows lowered RPMs, the regen bars light up, and the speed is maintained. No argument that my foot is more accurate than the cruise, but the penalty for using cruise on our Insight at highway speeds is less than you would think... I'm not at all sure how cruise would affect a MT, but I would imagine the difference in mileage is much greater in a cruise-equipped MT Insight... =]
Old 02-02-2009, 08:09 AM   #9 (permalink)
Smile 2500 mile Round trip
Thanks y'all,
I am heading south to Fla. 2-11 with my girl, roundtrip 2500 miles so I'll let ya know what my cruising data is. That is only if my cruise kit is installed this week.
Joe
Old 02-02-2009, 10:39 AM   #10 (permalink)
Originally Posted by bryankwalton View Post
... cruise control is generally designed to maintain a set speed -- even on hills. When hypermiling, if you allow yourself to decelerate some going uphill and either let off on the pedal ...
Rick Reece is an original hypermiler, long distance commuter and had cruise control installed. His report in these forums was that if he tired of the necessary hypermiler vigilance that the cruise could "beat" him MPG wise. Else it was the other way around. Usually a few MPG either way on his route. And remember his LMPG was in the 90's! :0
But the "key" to helping any cruise be more MPG friendly is add a _bit_ more slack in the control cable / chain from the servo to the throttle. AFAIK its a fussy balance but the added slack (up to a variable limit, varies accodring to terrain) adds some rollercoastering to the hills. With the expected MPG improvements.
HTH!
02 5spd, 130k+Miles
