Multiple Subpack Balancer - Page 7 - Insight Central: Honda Insight Forum
Old 12-09-2009, 04:23 PM   #61 (permalink)
Send a message via MSN to boelle
started to mod peters BMS slave program but got stuck.. any that can help out?
http://tina-og-bo.dk/v1stickbalancer.TXT
i get this:
Code:
symbol PreviousAmperage  = w7
Error: Unknown symbol - w7
basic what i want to do for starters is to messure the voltage and amps.. if the voltage is less than max voltage then it should charge if above max then do nothing.. later i want to expand so that i cycles between charge and discharge
Bo
"Who is the fool.. the fool or the fool who follows him?"
"No rest for the wicked"
"Blessed are the "cracked" for it is they who let in the light."
"Life is to short, dont waste it... too much"
"I'm not crazy, they just forgot to lock the door at the mental hospital"
"Intelligence is the ability to articulate one's stupidity"
"The difference between genius and stupidity is that genius has its limits"
"The true genius has no limits"
boelle is offline   Reply With Quote
Old 12-09-2009, 06:07 PM   #62 (permalink)
my latest code "fart":
http://tina-og-bo.dk/v2stickbalancer.TXT
ignore 20m in schematic.. figured i needed the x variant
Bo
Old 12-10-2009, 02:03 AM   #63 (permalink)
Bo
Read the PICAXE basic manual from cover to cover first. That's what I did.
w7 is not allowed in the 20M variables only go upto w6.
Also make sure picaxe software is set to correct chip
i get this:
Code:
Old 12-10-2009, 05:34 AM   #64 (permalink)
i did change it to a 20x2... but i guess i will be reading again... I just hope that i will unerstand it
i for sure know what i want it to do
also i have not added the opto's yet
Bo
Old 12-10-2009, 08:16 AM   #65 (permalink)
wow....
for the 08m i managed to have a LED flash when pin3 was high...
read all of section 1 but did not catch how to use inputs on the 20x2
guess it's on with section 2 then
Bo
Old 12-10-2009, 09:09 AM   #66 (permalink)
section 2 did not help me much and the same for section 3.... so i will look for a "picaxe for extreme dummies" guide
Bo
Old 12-10-2009, 11:19 AM   #67 (permalink)
just did some updates to the design:
the schematic: http://tina-og-bo.dk/stickbalancer.pdf
vsm design file: http://tina-og-bo.dk/stickbalancer.DSN
doing thoughts on what could be left out without loosing the intended functions.. i guess flashing the leds in sequence over and over could be used to indicate a bad stick so there is no need for extra leds
is the 20x2 a bit "overkill" for these tasks:
charging while messuring volt and amps and send that to master module
discharging while messuring volt and amps and send that to master module
figure out when a stick is bad (ah not within range after 6 cycles of charge/discharge)
doing trickle charge after 6 cycles and the stick is marked ok
should the number of cycles still be 6 if the stick is ok after 1 cycle? could reduce the time to do the balance
for the charge part a stick could also be marked bad if it tops before it should... if top voltage is not within range
for discharge similar way could be used.. if the stick hits knee point faster than it should...
Bo
Old 12-16-2009, 11:44 AM   #68 (permalink)
have been monkeing around a bit and so far i have modified the slave code to start charging and then when the cells peaks it will discharge if the cells then go under a set voltage it will start all over again
is it possible to figure out the ah number if the charge/discharge current is fixed?
i plan to add another pic to disconnect the stick after 6 cycles
Bo
Old 12-21-2009, 12:06 PM   #69 (permalink)
been thinking and fooling around a bit... came up with a total different idea
a charger based on National Semiconductor LM3647, what it will be able to do is:
when a stick is connected it will first discharge to the minimum level, as i have not build it or tested it i can not tell what it will do if the voltage is lower than that
next phase is a charge at 0.2C (0,65 A) for about 5 min if the temp is within -5 C and +50 C. it will abort if the voltage goes above 3.017 Volts or stays below 1.2 Volts
next phase is a charge at 1C (6,5A) until neg delta is detected (17mV/cell). the Charger can optional be fitted with temp messure probe to terminate if the stick get to hot
next phase is topping charge at 0.2C at a setable time
last phase is maintence charge at 0,1C (0,325A)
to recondition a pic that repeats this 6 times (by disconnect the stick at last phase and reconnect) should give most features needed.. only missing option is to count AH
but is it of much use? i figure the unit could be used to rent out to those who have trouble with their pack.. but please comment
Bo
Old 12-22-2009, 10:56 AM   #70 (permalink)
Vendor
One of the big problems with all the chargers out there is that they are designed for a couple of cells or at least a set of matched cells.
The very real problem here is that these subpacks are not in good shape. Let me give you a very real scenario. Here's the voltages of the cells of a hypothetical pack (like dozens on my shelves):
1.1V
1.2V (high IR)
1.1V
1.1V
0.2V (low IR)
1.1V
Total subpack voltage: 5.8V
What happens when you start your initial discharge and take it down to 5.4V?
What we need is a charger that will sense a low-charge condition and start an initial CHARGE not discharge.
