Mounting and readouts for Scanguage II - Insight Central: Honda Insight Forum
Old 02-28-2009, 05:04 PM   #1 (permalink)
Premium Member
Default Mounting and readouts for Scanguage II
Just got my new toy. I was wondering where people are mounting them. I know there is at least one magnet mount under the radio on the console and that looks like a place that the velcro would work as well. Other locations?
What about wire routing?
What do people like to see running routinely?
One recommendation that I have is the LOD/ LBN on the guage to judge when in lean burn, and the manifold and engine temp to monitor the engine block. Other recommendations?
Thanks
2000 Insight, red 160k. "Tardis"
IMA battery replacement done at 97 K.
Milage: 65mpg on 80 mile commute summer, 55 in winter.
seabag is offline   Reply With Quote
Old 02-28-2009, 05:35 PM   #2 (permalink)
Vendor
I have mine mounted above the rearview mirror.
MGT Motorsports.com | BlendMount
Old 02-28-2009, 06:20 PM   #3 (permalink)
Premium Member
Had not occurred to me. How much of a hassle was routing the cable under the headliner and down the A pillar?
Tnx
Old 02-28-2009, 10:03 PM   #4 (permalink)
I mounted mine with the velcro just underneath the radio. I have been happy with that location over the past 8,000 miles or so. I ran the wire up from the gap between the lower dash and the center console. It's exposed, but not very noticeable.
Some have drilled a hole underneath the radio lower trim panel and run the wire through that. I didn't because I don't like drilling holes in my Insight.
Patrickmilburn is offline   Reply With Quote
Old 02-28-2009, 11:31 PM   #5 (permalink)
Vendor
Tnx
It was pretty easy. I had to take out the A pillar garnish (plastic), but that was all.
Old 02-28-2009, 11:56 PM   #6 (permalink)
freezin4's Avatar
I've heard of some people mounting it in the "driver's storage compartment". (The little flip-down box under the power window switches.)
