Does anyone know if this is fixable? - Insight Central: Honda Insight Forum
Old 03-23-2009, 09:17 PM   #1 (permalink)
Vendor
Default Does anyone know if this is fixable?
UPS damaged a battery that was shipped to me.
This is a picture of a good board:
http://www.ronaldhansen.com/ima/damaged/img_5422.jpg
And this is the damaged one.
http://www.ronaldhansen.com/ima/damaged/img_5423.jpg
Side view of the component just to the left of the center (just left of
the brass-colored tube edit: DC-DC CONVERTOR FUSE). The top is cracked open. edit: HIGH VOLTAGE CONTACTOR
http://www.ronaldhansen.com/ima/damaged/img_5429.jpg
And a matching shot of the good board for comparison
http://www.ronaldhansen.com/ima/damaged/img_5430.jpg
Bad http://www.ronaldhansen.com/ima/damaged/img_5433.jpg
Good http://www.ronaldhansen.com/ima/damaged/img_5434.jpg
Top view of the same component:
Bad http://www.ronaldhansen.com/ima/damaged/img_5435.jpg
Good http://www.ronaldhansen.com/ima/damaged/img_5436.jpg
The component directly above it (this appears to sense the current with a
EMF loop) edit: MPI MODULE CURRENT SENSOR
Bad http://www.ronaldhansen.com/ima/damaged/img_5437.jpg
Good http://www.ronaldhansen.com/ima/damaged/img_5438.jpg
Side view of the white component in the lower left edit: BATTERY CURRENT SENSOR
Bad http://www.ronaldhansen.com/ima/damaged/img_5431.jpg
Good http://www.ronaldhansen.com/ima/damaged/img_5432.jpg
And of course, the blue connector:
Bad http://www.ronaldhansen.com/ima/damaged/img_5439.jpg
Good http://www.ronaldhansen.com/ima/damaged/img_5440.jpg
The blue connector actually looks like it still works (with a little tape
to hold it together).
Old 03-24-2009, 12:28 AM   #2 (permalink)
uhtrinity's Avatar
I wouldn't use a broken HV Relay, too much relies on it's operation (safeties). It would be very bad if it was stuck on. The current sensors should either work or not. I would probably just replace the output board with one from a bad pack.
Mark
2000 Silver Insight, #5550
Old 03-30-2009, 06:51 PM   #3 (permalink)
just use your old one control board- it replaces easily
but becareful what you are touching
newsracer is offline   Reply With Quote
Old 03-30-2009, 08:05 PM   #4 (permalink)
Vendor
It turns out that Majestic actually sells all the parts for the board.
