I jumped on 2X of the 4 ea deal this weekend. I'm not exactly sure how I will implement them yet. One consideration is one charger per pack, current limited using the LM317HVs like with my variac charger. Just unsure if I will use 3 or 4 of the ebay special power supplies or if I will use 3 and a third current limit supply like Mike suggests.
Btw, quickly approaching the 2 year mark on plugin charging. That will make ~600 full cycles and no issues to date. Mpgs will also be going up as I am moving and will have a 30 mile daily commute vs my current 2 mile commute.
Either I've missed the thread or I've forgotten, but if you are just buying a set of these now, how have you been charging your parallel pack setup before?
He is probably wondering why they suddenly are popular.
When I bought from him, he had two auctions for the "SR-25-48" running at the same time, one showing 8 available (4x and another showing 10 available (4x10).
2000 MT 146,000 miles
Bought 1/23/2010
I ordered from TRC Electronis. It was about $30 with shipping. $16.57 plus $5 handling plus $8.50 shipping.
Randerson, thanks for the tip on the e-Bay power supplies and TRC. For some reason TRC decided to charge me more, but at least I got one. Copied from e-mail:
LPC-20-350 1 1 16.5700 16.57
Constant Current Mode
IP67, 350mA LED Power Supply
LED or General Applications
HANDLING FEE 5.00
Subtotal 21.57
Freight 15.83
Total 37.40
Just to let people know...freight was lowest available ground UPS.
At 600 full charges I guess you are the test example. How many amps does this circuit charge at?
I'm charging 2 battery packs, so my numbers will be a little higher. The beginning portion of the charge starts near 1 amp, but quickly drops to ~600mA ... end charge is near 200 - 300 mA. This is based strictly on voltage of the pack vs voltage of the charger. The cooler months aren't an issue, I can actually leave it plugged in all day. In the summer I need to watch it more closely or the packs can get hot even with the fans running.
I just got the 4 power supplies. I didnt realize how small they were. I just bought 8 more of them. Those are one hell of a bargain at $5 each. I can use them for all sorts of things. 5 of them in series will give me the HV for a 100 watt Ham transmitter!!!
can i have a direct link to the auction you used.
2000 silver insight
lmpg 54.2 and rising
bought on 1-24-10
158654
