You don't want to lower the resistor or your hysteresis will be huge.
I have not really understood the whole hysteresis concept/principle, yet. So I may well misunderstand what "huge" hysteresis means in practical terms.
I have spent the last few hours with a resistor wheel attached in parallel with the 4.7MOhm hysteresis resistor.
I ended up soldering a 20kOhm resistor in parallel with the 4.7Mohm resistor, just because it is to hard to get the 4.7MOhm resistor out!
The effects of changing the hysteresis have been varied and somewhat unpredictable (for me, anyway)! The cut-in and cut-out point get further and further removed from each other the lower the resistance of the hysteresis resistor gets. Below 33KOhm I get pretty good suppression of the on-off-on-off behaviour.
For the "Special Freddy" charger it is extremely important to avoid rapid switching off and on, because sooner or later the sine wave on the motor-run capacitor will be "opposite" to the voltage when it was switched off last time - that creates an excessive voltage across the capacitor, up to 576V. Not good!
A much better solution is to low pass filter the 12V power supply for the comparator with a big capacitor 500-1000Uf. That will stabilize the voltage so the fan noise on the 12V supply cannot get to the comparator.
100 uf across the PTC, another on each of the setpoint potentiometers center tap should filter those signals further reducing the noise.
I was pondering these options, without knowing what exact capacitor values to choose - I was hoping you might mention them! Thanks!
But I broke my own rule 1 for prototyping: USE A BIGGER BOX!
And now I have very little, if any, space left in the box.
Quite apart from all this, the charger is not working at all. I think it might be due to the solid state relay having been damaged due to reverse polarity on it's "coil" terminals. But that needs more testing, tomorrow. I've had enough of it for today!
This is what I am trying to put together:
But often a good nights sleep solves the trickiest problems......
Thanks again for your help!
