Originally Posted by uhtrinity
I'm thinking that pack has just gotten too hot too many times. Was the car ever garaged or was it always in the sun? I wouldn't think a Civic would cycle the pack to heavily, so maybe it could be the environment. I know the Insight won;t throw a fault until the pack as a whole hits 140 - 150 degrees, maybe the Civic is the same.
That may be the case. I didn't think of ambient heat. It's definitely not heat damage from a stick going critical, because there would be a pattern of lower corner to upper corner due to the 45 degree location in the back seat. The pack was throwing a P1449.
Would ambient heat randomly affect the cells? Here are the final 4th (or 8th or 12th) cycle discharge capacities:
Bottom row 1st cell in string (let's call it "front") to "back"
4460, 3851, 2111, 4706, 3354, 5629, 4620 (lower corner)
Middle row from "back" to "front"
5885 (above lower corner), 2880, 4711, 2788, 2599, 2924, 1866 (below upper corner)
Top row "front" to "back" (end of string)
5580 (upper corner), 1620, 4851, in progress, N/A, N/A
Normally, I don't allow more than a 5% variation between sticks. Here I have 300%.
I think I'm going to have to scrap all but 2 (go with 5500 - excellent) or maybe 6 (go with 4400 - low normal) sticks. Note that these numbers are from a 10amp charge and therefore read a little low due to wire losses (heat loss in the cables). It really only matters in how they compare to each other, not the overall numbers. I typically see a max of 6200 at these charging rates.
Some of the cells show notable improvement from the 3rd to the 4th cycle, so I will give them some more cycles to see how they end up. Others, most notably the 1st stick show a DECREASE. The 1st stick numbers were:
D1 2487 C1 4862 (started with half a charge - 2487)
D2 4789 C2 5789
D3 4975 C3 5941
D4 4460 C4 5777 (you'd expect the 5777 to be lower than the 5941 because the battery isn't as empty with the 4460 as it was with the 4975)
Note that D4 was down from D3. There was a 20 minute rest between cycles, so heat should have no bearing. I'm taking them down to 0.9V and using a 5Mv delta-V.
Another example of this is #14
D1 0404 C1 2804
D2 1862 C2 2906
D3 2023 C3 3228
D4 1866 C4 3068
I'm going to put a more advanced charger on the pack tomorrow and see if it can improve some of those numbers.
Maybe his fan (in the trunk) is blocked or failed?
