Originally Posted by MrChoi
i forgot to turn off the brake light today from the forced regen mod and it drained the batteries to about 8 volts in 6 hours with the stock battery.
Why wouldn't you use a momentary switch for the regen mod?
Better yet and safer, Why not
slightly adjust the standard switch so that the lightest touch of the brake pedal activates the regen without using the friction brakes? That way, people behind you really know when you are applying the brakes (to some extent) and they will never be left accidentally on. Then perhaps people behind you will not be concerned when they see your brake lights on even when going up hill.
If they are on constantly (forgot to turn off the switch), and you had to hit the brakes hard to come to a sudden stop, the driver behind you may not be able to react properly since they would not see any visual difference in your lights. If there was an accident, the other driver could make a case that you are partially (if not totally) responsible since you modified a safety feature that normally warns other vehicles of your intent to slow down or stop.
