I don't know about the actual filter you have (whether it is right or not). However, you should note that the original oil filter for the first gen Insight is shorter than the "new" filter for the first gen Insight. Some time ago, Honda made a change, and the official filter is now the same kind used in the second generation Honda Civic Hybrid. These filters are the exact same specs except they are a little longer. So, I'm guessing that you originally had the "newer" filter on your car. And the filter you just purchased is actually the older spec filter. But again, I know nothing about the actual filter you have purchased.
Cheers,
Bryan
2000 Honda Insight -- Lifetime Fuel Economy of 71.6 MPG
