This note is being written to help those who, like myself, may be a little hesitant to attempt trickle charging their Insight high voltage battery pack.
Before trying this myself, I spend several months following the forum and asking many questions to make sure I could attempt this without either hurting myself or the car.
Of course after doing this once, it all seems allot easier now.
I have posted some pictures here:
http://picasaweb.google.com/threewhe...ickleCharging#
I should mention that after removing the high voltage breaker cover, you will see a black breaker switch that is held in position by a red, slip-on tab. Please remove the tab before trying to turn-off the breaker.
Once the breaker is switched off, all voltage is removed from the main battery posts on top of the battery. However, I wore rubber coated work gloves as a safety precaution any time I was near the battery. I also double checked voltages with two different meters, to ensure that all voltages were safe before disconnecting anything.
The weight of the battery is close to 70 pounds as measured on a bathroom scale, and I was able to remove and reinstall the battery alone, although two people would make it easier as the manual shows. I grabbed it by the back and front, just underneath the ductwork by the fan.
I should mention that although I used a variac with full wave bridge rectifier, this setup takes more attention from the user, as the current level keeps changing as the voltage level rises. Mike's constant current setup would be much better for this application.
I hope this will encourage anyone who is thinking of pursuing trickle charging your battery to give it a try. But please use care and common sense when working with high voltage. As Ron the Hybrid Battery Repair man says, 'keep one hand in your pocket' when working with high voltages.
Jim.
