Volumetric Efficency? - Insight Central: Honda Insight Forum
Old 08-08-2009, 06:08 PM   #1 (permalink)
JimIsbell's Avatar
Default Volumetric Efficency?
I have the latest Beta software for TouchScan which uses the OBD-II interface to compute MPG. Without MAF information which the Insight does not provide it uses another method to compute MPG. In the computation, one of the fixed inputs is the Volumetric Effiency. It is presently set at 65% but I can change that as need be.
Anyone know a good value to use there for the 1 liter Insight engine??
Old 08-08-2009, 07:45 PM   #2 (permalink)
uhtrinity's Avatar
Couldn't you figure out what it should be by calibrating against the Insight's instantaneous mpg meter. That assumes that VOL EFF is a fixed value.
Mark
2000 Silver Insight, #5550
Old 08-08-2009, 09:57 PM   #3 (permalink)
924guy's Avatar
if you want to do the math....
Volumetric Efficiency:* Calculating your cars volumetric efficiency
Eric...
No normal cars for me! Ill be back when i get the CRZ...
Y2K Insight-New Formula RedSold!
1999 Isuzu VehiCross-ebony black SOLD!
1978 Porsche 924-building into racer. soon to be daily driver.
1982 Porsche 931- building into road endurance racer!
project on indefinite hold.
924guy is offline   Reply With Quote
Old 08-08-2009, 10:20 PM   #4 (permalink)
All I can tell you is, on my ScanGauge II, when I set the engine displacement at .8, the MPG display perfectly matches the Insight dash display. I don't know if that will help you...
Old 08-09-2009, 06:10 PM   #5 (permalink)
JimIsbell's Avatar
BUT...isnt the diplacement 1.0? If so, then are you are compensating for an erroneous Volumetric Efficiency?
I will try 0.8 and see if it works. Right now it is reading HIGH
I am NOT using ScanGauge, I am using TouchScan on my mini PC.
Old 08-16-2009, 04:11 PM   #6 (permalink)
JimIsbell's Avatar
The problem has been partially fixed by changing the software and removing a filter. I am still using 1 litre for the engine size and it now matches the FCD up to about 95mpg but it flattens out there and the TouchScan reads a bit low so I think I will try adjusting the VE.
