Originally Posted by 924guy
interesting....
what in the headlight system causes a force charge for the ima?
It doesn't cause a typical force charge for the IMA......
It just keeps the IMA battery topped off but not from the typical force charge that is normally spoken of.
Here is what I think happens:
Since the Insight does not have an alternator, the 12V battery and the 12V accessories get their power from a DC to DC converter when active.
Under light electrical load (no headlights on - no fan on high), the DC to DC converter is not active at all times. When it is not active, all 12V voltage comes from the 12V battery.
When the DC to DC controller activates, the accessories and the 12v battery receive 12v (charging the 12v battery as well).
This is why you see the voltage go back and forth from 12V or so to 13.8V or so. When the voltage is above 12V, the DC to DC converter is activated.
The IMA motor is also a generator. When the lights are turned on (or fan turned up to high), there is a high electrical load and the DC to DC converter is called to
be on at all times. Here is the theory part....The DC to DC converter does not need all of the voltage that the IMA motor and inverter can produce even at minimum IMA generator mode request, so the remainder voltage does to the 144V pack until it is deemed to be full enough.
When you have an aging IMA battery, the headlights on trick can keep it topped off with this method but it is not really a typical force charge.
