Roof rack??? - Insight Central: Honda Insight Forum
Old 08-19-2009, 05:32 PM   #1 (permalink)
Post Roof rack???
I have just bought a 30,000 mile 1st Gen Insight but I'm also a cyclist. This does not seem to be a happy combination? I only need to carry 1 bike at a time.
Can anyone tell me if the car can take a roof rack, other than inflatable types? I'm concerned that the rear is too narrow, height wise, and that the rear window is too steep a rake for a conventional rear mounted bike rack and that I am in danger of scratching the paintwork with the conventional ties that are used.
Would it be possible to mount a tow bar for this purpose, as these are sensible for carrying bikes away from the vehicle. I'm concerned that the aluminium chassis would not be able to sustain a tow bar?
I really need your expert help. I live in the UK if that makes any difference to anyone? At about $7.50 per gallon this is the best car investment I have ever made.
Thanks in advance
Carlos6633 is offline   Reply With Quote
Old 08-19-2009, 05:42 PM   #2 (permalink)
JimIsbell's Avatar
The chassis must be able to carry some load as I read somewhere that there was a factory towing package available. I havent the foggiest idea what it consisted of.
Old 08-19-2009, 05:49 PM   #3 (permalink)
Post
Thanks for the quick reply.
I guess that it can take some load, as you say and if Honda issued a tow bar kit then I will ask them here in the UK.
Regards
Carlos
Old 08-19-2009, 07:32 PM   #4 (permalink)
02insight's Avatar
here is a link to some member who created thier own hitch and adapted some kind of trailer. Explore their site, there are many useful mods there...
Bike rack hitch
Old 08-19-2009, 09:14 PM   #5 (permalink)
bryankwalton's Avatar
I don't know what kind of bicycle you ride, but a few points:
1. Saris makes a roof rack for the I1.
2. Any bike rack will destroy your incredible fuel economy.
3. You can fit a bicycle inside if you remove the front wheel and scoot the passenger seat up -- this has been done many times.
Cheers,
Bryan
2000 Honda Insight -- Lifetime Fuel Economy of 71.6 MPG
Old 09-18-2009, 05:22 PM   #6 (permalink)
I just finished fabricating a roof rack systen for my I1. I installed plates with nuts welded to them at the 4 corners of the roof just under the roof skin so when I take the rack off all that is visible are 8 screws to fill the holes. I also filled the gap between the plates and the roof ribs so the ribs carry the weight.
I used unistrut for front/back rails on each side which is very adaptable and one of the devices I bolt onto it is a bike rack. Ski rack and something to carry plywood or pipe is next.
So far it works perfect and absolutely zero flex. I have not ried to lift the whole car up by the rack (yet) but may try it someday.
daver277 is offline   Reply With Quote
Old 09-18-2009, 08:51 PM   #7 (permalink)
I have done this with much success.
nayrhyno is offline   Reply With Quote
