I've added more photos to my PHEV Insight album on Flickr.
Enginer PHEV in a Honda Insight - a set on Flickr
It shows my current configuration with the batteries near the back of the car and the converter nearer the front of the car.
This allows more airflow under the stock electronics. It also makes for a handy way to add a piece of foam core board on top of the batteries to create a storage shelf.
Currently the whole system is mounted on a 1/2" piece of plywood that is bolted to the car using the spare tire hold down threaded hole. I'm getting a metal plate made to replace the wood, but the wood works for now.
I've been using the pack for the last few weeks and getting the hang of things.
I use the Enginer's panel toggle switch to turn on the Enginer system as well as to turn it off when the balancers low voltage alarm goes off.
I have been using MIMA to
- manually control the amount of assist used
- limit or turn off regen from the Insight's electronics when the pack is low
- turn off the Insight's engine to coast where safe and legal to do so
It is not directly interfacing or controlling the Enginer system in any way.
With that, here's what I've found:
- recharge time for the Enginer pack from the grid (~2.25 hrs)
- recharge time of the stock pack from the Enginer pack when parked with car in accessory mode (~45 min)
- recharge time of stock pack from Enginer pack while driving and not using assist (35 minutes)
- amps into the pack from the Enginer pack.
---- generally ~8 amps or so when battery is low (0 bars- 133 V)
---- generally ~6 amps or so part way through (12 bars -165 V)
---- generally drops an amp or so as each bar is added and voltage moves closer to 170. (in the run I made, the voltage difference in my car between 14 bars and 20 bars is less than a volt.)
Using things in this manner I have been able to run around town using a heavy amount of electric. This allows me to do 2 mile trips to the store and be at ~125 mpg.
I also have done a 19.4 mile run out to the country and back to town on an errand and got 114.2 mpg. I started with a full stock pack and full Enginer pack. I depleted the stock pack and the Enginer pack on this run.
I did a 40 mile run on the highway (55 mph) and got 108 mpg. Again starting with a full Enginer pack and full stock pack, and depleting them both.
Having MIMA available to control the use of the assist and to turn off charging from the Insight's stock programming has been helpful in keeping mpg's high.
Please feel free to contact me with questions or other things you'd like me to give a try.
