changing my own oil - Page 2 - Insight Central: Honda Insight Forum
Old 09-07-2009, 01:12 AM   #11 (permalink)
As Arnold would say----You can do it!!
2000 mt. ac.
257,000miles
Old 09-07-2009, 12:13 PM   #12 (permalink)
well after about 4 hours, a few issues, including a 45 minute trip to the nearest 24 hour walmart at 3am(i realized after i started i had no oil filter wrench)
my insights oil has been changed!
i put 3 full quarts in. in only bought 3...after i put the recommended(by the manual) 2.6 in, i checked the level and it was only about 1/3 of the way up in between the markers. so i added the rest, no its about 2/3...
so it is definitely more likely to be 3.4 quarts total
should i go out and buy that extra quart? or is leaving it 2/3 ok?
thanks for the help guys!
2000 MT Red. Pioneer head unit with iPod direct link. Dead IMA.
LMPG: 57.0mpg over 198Kmi
OMPG: 57.7mpg over 104Kmi
Best tank: 70.2mpg over 633mi
Best short trip: 87.8mpg over 18mi
Best long trip: 70.5mpg over 103mi
Best round trip: 76.1mpg over 46mi
ikhoudvanu199 is offline   Reply With Quote
Old 09-07-2009, 12:18 PM   #13 (permalink)
Premium Member
satchel's Avatar
If you put 3 quarts in you've overfilled it.
New Formula Red 05 MT 116784m
Ad Astra per Aspera
Old 09-07-2009, 12:22 PM   #14 (permalink)
oh? i sure hope not. i really looked low with just the 2.6 quarts in...
and i ran it for a few minutes, then checked the level right after...then let it sit for a few minutes, then checked it again...and repeated...
geez, changing my motorcycles oil was sooo much easier than this, haha
Old 09-07-2009, 01:12 PM   #15 (permalink)
did you use a honda filter? Is it possible that you have the wrong dipstick?
2000 mt. ac.
257,000miles
Old 09-07-2009, 01:30 PM   #16 (permalink)
Make sure the "dipstick" is fully depressed (bottomed) before extracting it. That could give you a false reading.
Old 09-07-2009, 01:38 PM   #17 (permalink)
Oil level should be checked when the engine is cold, only then the oil is resting in the oil pan... when it is warmer/hot much of the oil is at the head and other paces so you will not get a correct read
Old 09-07-2009, 04:06 PM   #18 (permalink)
No, oil should be checked warm.
After the car has warmed up or been driven, park on level ground and shut off engine. Wait about a minute or two (owners manual is silent, it simply says "wait a few minutes"), and then measure. Most of the oil will be back in the pan. Cold oil usually will give a false high reading.
Simple to do when fueling. Typically, by the time you prepay, select your grade and put the nozzle in, you can check the oil.
There are some cars that have very specific procedures, this car does not seem to be one of them.
If the level is within the hatched marks, generally you are fine. The difference between high and low is generally 1 quart. Since the insight has such a small capacity, it may be less the Owners Manual is silent; but if unsure, add a 1/4-1/2 quart at a time and recheck.
Regards,
Jerry
Old 09-07-2009, 10:25 PM   #19 (permalink)
i did not use a honda filter, but it was the same part according to auto zone
i checked it a couple times today, and everything seems ok
Old 09-07-2009, 11:57 PM   #20 (permalink)
In that case-I'd bet the filter is a bit larger then OEM. But thats ok-as long as the oil is not over the upper line on the stick. Just wondering, was it a fram or stp filter?
2000 mt. ac.
257,000miles
Tags
change, filter, mobil, oil
