The Right Switch? - Insight Central: Honda Insight Forum
Old 10-02-2009, 10:45 AM   #1 (permalink)
jf_cole's Avatar
Default The Right Switch?
Im putting in 3 switches on the car next week, One will cut the TPS mod (handy for urban driving), One will kick in the Clutch switch (IMA Disable) and one will kick in the brake switch (Forced Regen).
This is the siwtch for the first two;
12V Black round ON / OFF rocker toggle switch 10A NEW on eBay (end time 31-Oct-09 17:24:46 GMT)
This is the momentary switch for the brake one;
Round rocker switch momentary OFF (ON) 20 mm hole black on eBay (end time 17-Oct-09 19:05:44 BST)
Can you guys let me know if the rating of these are OK? Im not nearly as full bearded as I would like to be and dont know too much about electronics. My mechanical friend is going to wire and solder them in for me, but wanted to get the correct switches first.
Thanks!
2000 MT Insight Citrus 55k
TPS Mod (on/off Switch for Town & Sport/Motorway)
IMA Switch
Regen Switch
Scangauge II & 6" Rad-block
S2000 Steering Wheel
Flat Wipers
Pioneer MP3 Head Unit
Alpine Component Speakers
Original Door Speakers installed Into Rear
HID's & LED's
Sound Deadened
Grid Charger
jf_cole is offline   Reply With Quote
Old 10-02-2009, 11:51 AM   #2 (permalink)
They look fine.
Old 10-02-2009, 12:12 PM   #3 (permalink)
jf_cole's Avatar
Wohoo!
Thanks mate.
IMA Switch
Regen Switch
Flat Wipers
HID's & LED's
Sound Deadened
Grid Charger
Old 10-02-2009, 12:46 PM   #4 (permalink)
02insight's Avatar
I would get switches that require little attention while driving, those ones seem fine. Also mount them in a place that you can easily reach without taking your concentration off the road. I mounted my switches in the area between the shifter and the Handbrake, since you would normally rest your right hand there anyway while driving and you dont want to be looking at the switches while driving anyway.
Old 10-02-2009, 12:52 PM   #5 (permalink)
jf_cole's Avatar
Thats exactly where I wanted them, just on the black plastic between gear shifter and H'brake. Right at your hand when resting. Cant wait to get these done!
IMA Switch
Regen Switch
Flat Wipers
HID's & LED's
Sound Deadened
Grid Charger
Old 10-02-2009, 01:21 PM   #6 (permalink)
I like having mine on the front of the shift knob because I often want to do these things either right before or right after shifting. So I put them right where the last segment of my fingers rest while I am holding the knob. I splay my fingers apart slightly when I don't want to engage the switches. Sort of as shown here:
Shift lever joystick mounts - MIMA Honda Insight Modified Integrated Motor Assist
only I did not make a leather cover. Your clutch and regen switches perform two of the functions of MIMA (which I have), so the uses are similar. Maybe the TPS switch could go elsewhere as I suspect it would not be flipped as often???
Old 10-03-2009, 10:41 PM   #7 (permalink)
JimIsbell's Avatar
If you do a forced charge using a brake switch bypass, I assume that if you hold it on too long the normal protective circuitry will still protect the battery from over heating and maybe even from overcharging too much???
Old 10-05-2009, 02:38 AM   #8 (permalink)
Correct! The regen soon throttles back.
