Originally Posted by nayrhyno
I have been thinking a lot about a MIMA system for my CVT. I like the way JoeCVT has his MIMA-L set up with the pedal. I thought about simply PM'ing him about this, but I think a thread would provide useful info for other CVT owners looking to maximize MPG with a MIMA, and I can't find many CVT specific MIMA threads. Maybe I am just bad with the search.
I have come to the conclusion that I want to make a CVT specific MIMA system.
Goals:
In a CVT, I think the most useful thing to have would be an analog assist/charge throttle. From what I have read about Joe's install, he has a pedal to control assist. I think the pedal is a great design, perhaps a pedal with a two mode operation would be best. Flip a switch one way and the MIMA is on and the pedal is assist control, flip it to the middle and the system is stock, flip it the other way and the MIMA is on and the pedal is regen control. I can't think of any other really necessary control to have, since FAS is not as simple for the CVT. The main goal is to use the battery more intelligently than the computer can. Increased assist up hills and less regen when a downhill is approaching.
Questions I have before I pursue this:
Is it possible to have the IMA system totally disengaged, ie no assist and absolutely no charge, even trickle charge?
Would this type of operation be possible with the MIMA_L circuit?
Is it practical (assuming I have the necessary skills and motivation to undertake the project) to try and design this myself with the MIMA_L if I don't need the increased functionality of the full MIMA system?
Joe, did you ever add to your system the ability to cut the regen/recharge?
I still have my original MIMA_L board installed and it is still working
with the pedal. In the current design, the pedal serves two functions. The MIMA is in the off state when the pedal is not pressed at all so the car behaves normally. As you start to press on the pedal, the increased voltage in the pot allows a transitor to apply power to the MIMA_L then add assist as you press down on the pedal further. On this current board, I do not disable IMA and have no regen control.
There have been a few times when I wish I had built-in IMA disable or a light regen when I want it to (and not the ECM) but the assist mode seems to be the most important function for how I used MIMA at the time
However, last winter, I did design a new board layout that would allow for multiple modes:
IMA disable
Pedal assist
Pedal regen
non-pedal preset assist
non-pedal preset regen
This new board layout would give me what I already have with normal mode to MIMA mode assist plus have assist / regen presets, IMA disable and pedal controlled regen.
I did not get a chance to build it this last summer but it is still on my mind.
Your idea of having a dual action pedal is right in line with my thinking except that I many use a dual pot due to auto activation.
I also designed another non-MIMA board layout that would replace two mode switches with a single momentary switch and two LED indicators (or one bi-color). Until then, two mode swtiches would have to be used until that other board gets built. The new MIMA_L board would be built first.
The pedal would get an upgrade to have a dual pot installed, one for regen and one for assist.
Also for temp setup.....Switch A and Switch B both connected to ground
Here is the idea of modes of operation:
Normal mode (no MIMA) - do nothing
Pedal assist - press down on pedal (turns on MIMA as pot voltage exceeds a set point being low pedal pressure) then provides from min to full assist levels as you press down further on the pedal.
(The two modes mentioned above are what I already have)
Pedal regen - flip a switch (switch A) - a relay activates to swap voltage input from pedal pots to MIMA board. This relay will also keep power applied to MIMA board even if you don't touch the pedal. At this point, the default duty cycle is set to 50% so assist and regen are disabled (not called for). Then, as you press down on the pedal....regen with level based on pedal pressure.
IMA disable - flip the same switch A for pedal regen but don't press down on the pedal as described above.
Preset regen - flip the same switch A for regen, then flip switch B. Since switch A is in regen mode all we do with switch B is activate another relay to cutoff the pedal input and replace it with a preset voltage for regen amount desired. This could be used to charge the battery with very light regen without having to keep your foot on the pedal.
Preset assist - do not flip switch A to ground so we are still in assist mode. Flip switch B to ground and this will again cut off the input from the pedal and use another preset voltage for assist. This mode can be used for very slight but long inclines to keep a constant assist level. There are two separate presets on the MIMA board so you can have a different level of preset assist and regen.
The new MIMA_L wil have two more DPDT relays (for a total of 4)
The future enhancement board to replace the switches with one momentary switch will act as follows:
Switch A and switch B modes will be determined by the length of time you keep the momentary pushed in (called short and long push). Much like the power button on your PC performs two different actions based on if you press it in quickly or keep it held in for a few seconds. Switch A will be a short push and switch B a long push. On / Off for both switches will be a toggle mode. Default mode with ignition first turned on will be both switches in off mode (normal mode then auto MIMA on and assist with pedal push).
Also, switch B mode will have a five or ten minute timeout (then turn off) so you don't forget you are using preset assist or regen since you are not using the pedal in these two modes. A bi-color LED will indicate if both A & B switches, one or neither are currently grounded.
Neither board design has been put on bread board yet but I believe the new MIMA_L has a pretty good chance of working correctly from the initial redesign.
