A high power complete cycler may well be an option now if you have a high power bench charger and discharger. And it might actually be possible to use the OEM BCM to do the monitoring and the BCM interceptor or a variation of it to do the controlling by looking at the BATTSCI data bytes.
So you have a pack on the bench with control boards and bcm/mcm fitted as normal, you attach the high power charger/discharger to the grid charger points on the ima board along with a 350ma final balance grid charger. You plug the BCM device into the BCM which powers the BCM so it can do the monitoring. The BCM device watches the BATTSCI signals and controls the chargers/discharger/fans etc as appropriate. A nice little display could show us the BCM data, current, voltage, temp etc which is all now available.
I like this idea and will have a look into it.
I have a 3kw charger which can output 15-18A at reqd voltage. And a discharger can be made using a 220v/110v immersion heater and a bucket of water
This is brillant incisive thinking! Utilising of the Cars technical resources.
We could charge on the Bench or with the pack still in the Car too
Do you think the BCM could be powered independently by a seperate supply ( eg relay in the loom )?
The BCM interceptor could read and monitor the 12 byte digital messages on Battsci for PTC temperature, pack voltage etc and run the show as required.
Those 350mA CC supplies from Meanwell work out at £45, I found an IC the L200 Current/Voltage regulator up to 2Amps which cost less than £4.
The data/app notes are in the link, fig 26 in the notes show a high output voltage constant current circuit.
Link:
http://www.st.com/stonline/products/...re/ds/1318.pdf
