Inside the G1 MDM & more power! - Page 27 - Insight Central: Honda Insight Forum
Old 11-08-2012, 12:23 AM   #261 (permalink)
For the 4 MCM Current sensors
+5v > 1k Resistor > Signal > 1k Resistor > Ground
OBDIIC&C $50 inc software and blank pcb.
IMAC&C HCH1 Civic $50 inc software and blank pcb.
IMAC&C G1 Insight $105 inc software and blank pcb.
Old 11-09-2012, 10:19 PM   #262 (permalink)
steveo's Avatar
Send a message via Skype™ to steveo
ImageUploadedByAG Free1352517161.136887.jpgImageUploadedByAG Free1352517200.902334.jpg
Here is the mod i did, i have used 1k 1% resistors 1/4 watt and a 68ohms 2w 5% resistor in the mcm
I have tried to install the modded mcm & bcm and i got the following errors on startup
Does the 68 ohms have to be 1% also? I couldnt source one at my local electrons store.. Gona have to order if its the cause if the errors
P1585 & p1581
Sent from my iPhone using Autoguide.com Free App
2002 honda Insight 5spd
Mima/BCM Fooler/BCM Interceptor/50s2p 40Ah A123/30% current mod/1000w charger
To Do: Install PP50 Bms, Charge plug, Warm Air Intake, led & hid lights/avg 1.6L/100km or 135mpg+
HUDGE Red 2001 mk1 part out here...http://www.insightcentral.net/forums...-part-out.html
steveo is offline   Reply With Quote
Old 11-10-2012, 02:49 AM   #263 (permalink)
I can't see anything useful in those pics far too small.
Yes the 68R needs to be a 1% type. The whole accuracy of the battery sensor depends on it.
Old 11-14-2012, 09:56 AM   #264 (permalink)
steveo's Avatar
Default ....
I believe i've fixed the temp error i was getting.. I used 10k resistors wired in exactly how the original oem sensors where.. and am now using a 82ohm resistor to trick the ptc strips... all resistors are 1% 1/4 rated... since i know the insight is really picky... running for 2 days and no p1648 error or p1644 errors so far
thanks
-steveo
Old 11-14-2012, 10:11 AM   #265 (permalink)
Mike Dabrowski 2000's Avatar
Steveo
The PTC total resistance should be closer to 20 ohms. that is what the strips read in ohms in normal ambient temperatures. The pack has to get pretty hot befire the PTC will be at 83 ohms.
83 is the value that my charger reads when the strip is at 20 ohms, but that is not ohms, just a value.
Worth a try.
Old 11-14-2012, 11:29 AM   #266 (permalink)
steveo's Avatar
Steveo
Worth a try.
Hey Mike,
I originaly was using a 24ohms resistor where the original ptc sensors wired up .. so your saying 20ohms is ok to use instead of my 82ohms resistor? or even my 24ohms original resistor would of been ok..
I remember checking this with my fluke meter on the oem pack..
thanks
Old 11-14-2012, 12:42 PM   #267 (permalink)
The 24 ohms is fine, there seems to be a deviation of several ohms on the 6 or so that I have measured.
Just would hate to have you falling into a boundary condition.
Good luck
Old 01-12-2013, 10:50 AM   #268 (permalink)
steveo's Avatar
Hey everyone
I have changed all the resistors to 1% and im still getting the p1585 error
Now i bought these resistors of ebay, i dont know if maybe they are not really 1% who knows.. There probably our of china
Anyways, do you still think its the resistors? Im 99.9% sure its modded correctly.
Thanks
Steveo
Sent from my iPhone using AutoGuide.com Free App
Old 01-12-2013, 11:59 AM   #269 (permalink)
Which mod are we talking about?
BCM Fooler?
Current Hack?
Assuming you mean the current hack
It's possible due to some variation in the MCM's that the 1k etc is too low for your car and you can't shoot for such a large current increase.
I posted a spreadsheet and various other bits on how to calculate resistor values some time back. I suggest have a look through all that. I don't have the links you'll have to dig it out.
Peter
Old 01-16-2013, 04:05 PM   #270 (permalink)
steveo's Avatar
Here is a tiny excel spreadsheet for working out the current hack resistor values.
Type in a % increase number you want from say 12-20% and hit enter to get the values for the two resistors. Thanks to my long suffering wife for her expert help with Excel and the Maths
I have tested 12%, 15% & 17% increase so far with no problems, I might test 20% today if i get a chance. I found 25% did not work in earlier tesing, but might give it another go later with values from my spreadsheet.
% increases of less than 12% are not possible with the 3.3k potential divider i am using, but if someone wanted to try 4.7k resistors for the Pd then it may be possible to get lower % increases. Spreadsheet formula would have to be adjusted.
I recommend accurate multi turn (20) pots for the resistors. 1k for the BCM part and 220 or 500R for the MCM part.
Do not increase current by more than 12% without upgrading main IMA 100A fuse!
I recommend all connections/resistors are made/placed inside BCM/MCM modules to screen mods from RF noise.
PS
If you want to observe your new current you will need a special compensated version of the BCM gauge software, currently I have 12, 17 & 20% versions available by special request.
Hey Peter
thanks for pointing me in the right direction..
just to clarify on your diagram you used a value of 3.3k resistors (1% i assume) for r4 & r5... however you mentioned that it was ok to use a 1 k resistor now instead ... a couple posts back here... is that correct?
Also.. i noticed that my connection from the mcm current sensor does not have the "r6" resistor value you indicated in the diagram.. so this is most likley why i'm getting the p 1585 error
i will retest this mod when i have a chance..
-steveo
