Ocasional squeek in tront end - Insight Central: Honda Insight Forum
Old 01-02-2010, 10:54 PM   #1 (permalink)
JimIsbell's Avatar
Default Ocasional squeek in tront end
I am experiencing a squeek that is most noticable while traversing uneven ground at slow speeds. Usually from the left front wheel area but sometimes from the right front wheel area. What is it likely to be and what is the cure?
Old 01-03-2010, 05:15 AM   #2 (permalink)
The source of my front suspension noise
15 minute job on a ramp/pit
Peter
