MCM and BCM serial numbers/model numbers??? - Insight Central: Honda Insight Forum
Old 02-15-2010, 06:32 PM   #1 (permalink)
JimIsbell's Avatar
Cool MCM and BCM serial numbers/model numbers???
Several people have mentioned getting these parts replaced under warranty. I know MINE are NOT under warranty, but am wondering if they have been replaced. They are (both sets) working fine...I think. But I havent the foggiest idea what the symptom was that replacing them was supposed to cure?
When I have found numbers in reference to replacement, mine dont seem to even match the format so I cant tell if they are new or old.
One of my MCMs has the number 1K000-PHM-040 But also has the number 7650-501284 seemingly later stamped on it. It is also marked MT which I suppose means its from a Manual Transmission car. The matching BCM also has two numbers, 1K000-PHM-020 and the later stamp 7680-301265...no MT designation on the BCM
Are these "old" or "new" and what was the difference in what they did or did not do?
Old 02-17-2010, 07:39 PM   #2 (permalink)
Vendor
I *think* 040 means that it is the 2004 release. I know that there is an 070 version.
Old 02-18-2010, 10:14 PM   #3 (permalink)
Jim;
Have the dealer "run" your vin for any recalls or warranty work and that should tell you the information you need.
Old 02-18-2010, 10:23 PM   #4 (permalink)
JimIsbell's Avatar
Yes, I did that, but I dont trust the local dealer. If he saw that it might cost him money he would tell me everything was hunky dory and push me out the door.
The lady at the computer console told me 18 months ago that all recals and upgrades had been done. But then there is the matter of my second set of modules that came off the "junk" battery that was given to me.
Those are the ones I gave the numbers for above.
Old 02-19-2010, 03:09 AM   #5 (permalink)
TRI
TRI's Avatar
From the part catalog.
BCM
1K100-PHM-
-030 2000-02
-A00 2003
-A01 2004
-A02 2005
-A03 2006
MCM MT
1K000-PHM
-050 2000-02
-060 2003
-070 2004
-A01 2005-06
MCM CVT
-904 2000-02
-905 2003
-906 2004
-A50 2005
-A51 2006
2000, silver, 5 speed, #0071
TRI is offline   Reply With Quote
Old 02-19-2010, 11:21 AM   #6 (permalink)
JimIsbell's Avatar
That is what is confusing to me.
The MCM ends in -040. There IS NO -040 in that list!!!
the BCM ends in -020 and again, there IS NO -020 in that list!!!!
Even if I was mistaken and had them backwards, -020 and -040 dont exist in any of those lists!!!!
Old 02-19-2010, 12:25 PM   #7 (permalink)
Vendor
BCM
1K100-PHM-
-030 2000-02
-A00 2003
-A01 2004
-A02 2005
-A03 2006
MCM MT
1K000-PHM
-050 2000-02
-060 2003
-070 2004
-A01 2005-06
MCM CVT
-904 2000-02
-905 2003
-906 2004
-A50 2005
-A51 2006
I've got here:
1K100-PHM-020 / 1K000-PHM-040 MT
1K100-PHM-030 / 1K000-PHM-904 CV
Both of these sets fit 2000-2001 Insights.
Old 02-19-2010, 12:26 PM   #8 (permalink)
Vendor
Relax Jim. The list is incomplete. I have the same pair here.
