LED lights - Page 2 - Insight Central: Honda Insight Forum
Old 02-28-2010, 02:48 PM   #11 (permalink)
The other thought I had was to use a dowel pin or blunt screwdriver to test the depth to the lip of the "reflector." I don't remember how difficult the access was, but maybe use your thumbnail or a permanent marker to mark the dowel pin. I would leave a little cushion for heat dissipation (so the bulb is not pressed up against the plastic bezel).
Brett
Silver '01 5-spd 245K miles, Civic battery subpack swap
LMPG 76.1
bretthans is offline   Reply With Quote
Old 02-28-2010, 05:20 PM   #12 (permalink)
i will try a couple things this weekend cause i dont wanna buy a bunch of stuff that doesnt fit. lol
2000 silver insight
lmpg 54.2 and rising
bought on 1-24-10
158654
buzzkill is offline   Reply With Quote
Old 06-30-2010, 11:26 AM   #13 (permalink)
aisbell's Avatar
What did you end up doing?
In Sweden, all vehicles must drive with front-facing white lights on. These lights must be bright enough to be easily seen in full daylight. Most cars seem to have their low-beam headlights wired to turn on with the ignition. Canadian and European Insights apply only 6 volts to the headlights (not sure which beam) in running light mode (i.e., with the ignition switch on but the headlights off).
Having a U.S. Insight, my only option at present is to run with my low beams and taillights on at all times. Now that I have MIMA, I can see that this causes a continual forced regen to occur to keep the 12 v. battery charged. I can use MIMA to provide the necessary regen at more opportune times, but the better solution would be to use more energy-efficient daytime running lights. I might be able to replace the rather dim 5 v. incandescent 168 minibulbs in the front-facing parking lights with something like these 2 w. high-power LED's. Then I could wire these front-facing parking lights to turn on with the ignition with the rear lights turning on only when the parking lights are turned on manually. That would make my daytime running light power draw only 4 w., a small fraction of the power I currently use.
I am a little concerned that these longer LED's might be too long. Were you able to use the longer LED's? If so, were they noticeably brighter than the standard bulbs? The LED that I'm interested in claims to project 105 lumens of light, but I have no idea how that compares with the standard bulb.
Aloha,
Art Isbell
2000 Insight A/C #559
MIMA+FAS, Rostra cruise control, IMA battery charger/balancer, Fumoto oil change valve, block heater
Old 06-30-2010, 11:38 AM   #14 (permalink)
unfortunately nothing yet. i have all kinds of things come up requiring money to be spent on other things.
motor mounts
tie rod ends
poured a stamped concrete patio and landscaped
and on and on.
if i get a bonus from work this month i will order a set and let you know.
2000 silver insight
bought on 1-24-10
158654
Old 06-30-2010, 11:51 AM   #15 (permalink)
Art, I have done somewhat the same as you are thinking of doing, i replaced
the 5W parking lights with these LED's. Positionslys 3W/5W SMD 5000K (CANBUS) - Astina.dk
Due to my still not taxed car i have not had it on the road with these bulbs yet, but standing in the garage there is a realy big difference between these & the
original 5W bulbs, original is almost yellow compared to these.
Unfortunately due to the fittings used for the parking lights, these LED bulbs are the brightest available ( at least what i have been able to find) otherwise i would have bought a pair of these: Matronics - Hvid SMD LED pære - 12V (21Watt) 7440
They are rated an light output of 21W, which should be more than enough
as DRL.
I have measured the inside of my headlamps, and there should be space for a bulb that is up to 9 cm. long.
If you want to make your DRL legal, you will have to get a DRL module that
automatically turns your DRL on when engine running, and turns DRL off again
as soon as you turn on your parking lights or low/high beam.
Out of the back of my head i believe the parts must be E87 approoved.
2000 Red Insight MT. #032
IMAC&C & OBDIIC&C.
faxe is offline   Reply With Quote
Old 06-30-2010, 03:30 PM   #16 (permalink)
aisbell's Avatar
Your photos look good. Have you read any reviews about these lights? Unfortunately, many LED lights seem to fail rather quickly.
Are you saying that a bulb up to 9 cm long could fit in the parking light enclosure? That's way longer than the standard bulb or any multi-diode high-intensity LED that I have seen being sold. However, I'm a bit concerned about heat in the parking light enclosure, so I probably would not want to push the wattage too high.
If you want to make your DRL legal, you will have to get a DRL module that automatically turns your DRL on when engine running, and turns DRL off again as soon as you turn on your parking lights or low/high beam. Out of the back of my head i believe the parts must be E87 approoved.
I think that my Insight does not have to follow those regulations because it is an imported U.S. car. My Insight currently has no actual daytime running lights. I just turn on my headlights whenever I drive (I sometimes forget). So I think that I could just turn on my parking lights if there were bright enough.
Aloha,
Art Isbell
Old 10-13-2010, 02:56 PM   #17 (permalink)
3-Wheeler's Avatar
I remember reading about some of the problems that some Insight owners were having regarding use of LED tail lights and such.
Well, I can now say that I have been using SuperBrightLEDs for several days now and everything on the car seems to be working, including regen.
The lights are not the stock Honda affair but actually mounted on the custom tail extension as seen below.
The LED's work for me.
Jim.
2000 Insight MT; MIMA-CL; Radiator Block; Dabrowski Grid Charger; 90% Under-body coverage; Tail.
Old 10-13-2010, 05:25 PM   #18 (permalink)
Kevin Dougherty's Avatar
Jim, Very sweet, any test results yet?
kevin
Old 10-14-2010, 02:13 PM   #19 (permalink)
3-Wheeler's Avatar
Yes, I took pictures of the brightness of the standard bulbs and compared to pictures to the LED light intensities and both are very similar.
Jim.
Old 10-14-2010, 07:53 PM   #20 (permalink)
Are the LED's highly directional? Would someone approaching from a 45° angle have any trouble seeing you? That's been a conventional drawback of the technology, and I think some reflective strips would mitigate the problem somewhat.
It looks like you still have the same illuminated width as stock, which is nice.
Obviously we're all looking forward to data on the new aeromod, and I don't mean the radio antenna removal. Btw, if you relocate the antenna to inside the car (or inside the tail), you retain most of your radio reception.
