Age of sparkplugs?? - Page 4 - Insight Central: Honda Insight Forum
Old 03-20-2010, 01:05 PM   #31 (permalink)
02insight's Avatar
Originally Posted by JimIsbell View Post
My car has 210,000 miles on it!!!
wow.. i dont know what to say then. I'm impressed.
Old 03-20-2010, 07:40 PM   #32 (permalink)
joecvt's Avatar
I see no reason NOT to reuse them. I have been collecting and working on cars for over 55 years and I almost NEVER buy new plugs unless one actually fails.
The only potential problem I see in your thought to run the plugs until one fails is that this is a 3 cylinder engine. A V8 loosing a plug is not a real big deal nor a V6 for driveability but as you work your way down to 4 cylinder and 3 cylinder, loosing a plug becomes a pretty big deal.
It is not an easy road side job if you have coil bolts that are rusted / corroded like mine were (Two out of three had to be drilled out).
About 8 years ago, I had an Acura Integra ( 4 cylinder ) and on the way to work, all apeared to be fine....On the way back home about a mile from my house, my car started loosing power in that I could only do about 20 MPH. The spark plugs were way overdue for a change and that day, a plug change is all I did and had no problems afterwards. Didn't change the distributor cap or plug wires during troubleshooting (but changed the cap and rotor later on). Perhaps my experience that day was a weird event but after 105K in the Insight, those plugs deserve a rest IMO.... They are not too expensive if you buy online and avoid the dealership.
To me, it does not make sense that you would lose MPG if you replace your plugs with new correctly indexed OEM plugs (A, B, C or D).
No other mods performed yet
2003 CVT Blue Insight
Low Speed Auto Stop (LSAS)
Not registered yet
