I've done a great deal of reading about Nickel-Zinc and it has actually been around for quite a long time. People who used them in electric cars about a decade ago had failures, which were attributed to separator puncture failure as the zinc dendrites are formed as the zinc doesn't migrate back to the cathode easily, which has been the biggest challenge from the chemistry. I've also read about charging, they need to be charged at a specific rate between C and .5C, they can't take an overcharge like NiMh and NiCd either which makes them unsuitable for a hybrid car and in an electric car you would need to have a very high amperage 240 volt outlet to charge them in two hours if you wanted decent range for the car. I remember searching through the EV Album site at NiZn cars and there was no example where I read their blog where he was having issues with them getting too hot during discharge. Based on everything that I've read, they are far from ideal and no longer 'cheap' relative to other chemistries anymore. I don't even know if there is any accessibility to them anymore in prismatic form.
We currently don't get lithium from Bolivia and its cheap enough as it is and not the primary cost driver of lithium cells, especially Lithium Iron Phosphate which actually has far less lithium than you would think inside it. In 2008 Chile was the largest producer of lithium in terms of mining production, followed by Austrailia, China, Argentina, Canada, the list goes on. Production for Bolivia was zero. Although the large scale Lithium production cells aren't being produced here, the US gets 63% of it from Chile, 35% from Argentina, 1% from China, and 1% from all other sources.
Source:
USGS Minerals Information: Lithium
