I was about to suggest spacer rings as well, but someone beat me too it.
With a sub you do need to find a spot to mount an amp, and think about the extra draw on the 12v system. It WILL affect MPG, even if only slightly.
One thing to consider is a ser of component speakers. 6 3/4 mid range components can have bass response down to 30-50HZ. This is plenty low enough to get good bass in such a small cabin. It won't send you thumping down the street, but it will make your music sound nice.
In my experience, I like full range speakers up front (I have some with directional tweeters) and component for the rear with the tweeters mounted up front. I put mine in the space in front of the door handle, as someone else here posted.
Another thing to consider: Make sure you have enough power to drive your upgraded speakers. If you get speakers with over say 25W nominal RMS you will have a hard time powering them without an amp (ie with just a head unit). Typically speakers are rated with an RMS range. If you aren't using an amp, look for something in the 2-50 RMS range rather than the 15-100.
2002 Silver CVT w/ 105k miles... Here's to few more 100k's
61.3 ownership LMPG
